Axisymmetric geometry but not flow
Old   June 14, 2021, 06:26
Default Axisymmetric geometry but not flow
Thodoris
teodm is on a distinguished road
Hello everyone.
I am simulating the flow inside a cylindrical drum. I am using VOF multiphase and I would like to ask if I can put some rotation to the drum and simulate the problem as axisymmetric with swirl. I have attached my half geometry with the boundary conditions.
My problem here is that the flow is not axisymmetric because as water leaves the inlet it directs downwards due to gravity so I think I can't simulate it as axisymmetric with swirl. I am right?
As you can see in the picture, my geometry is inclined 3 degrees, so does that mean that I have to set a local coordinate system with the x-axis inclined as well or bt defining the axis boundary my x-axis becomes automatically aligned to the edges?
teodm is offline   Reply With Quote
Mathematica: steady-state compressible air viscous flow in a 2D axisymmetric step foadsf Main CFD Forum 0 February 21, 2018 13:39
Initialize flow from different geometry B.Axel FLUENT 2 January 24, 2018 14:15
3D axisymmetric flow in cylindrical coordinate = 2D cartesian flow? shubiaohewan Main CFD Forum 10 May 2, 2013 15:08
Level set equation in axisymmetric 2-D flow jinwon park Main CFD Forum 0 February 26, 2008 17:26
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
