Helical baffle Heat exchanger turbulence model |
Omer Mileguir
Rep Power: 0 ![]() |
I'm trying to simulate helical heat exchanger. I have experiment results to compare to it. I need a recommendation of turbulence model that i could use in order to calibrate my model. I used the k-Omega SST and got much higher dP and heat exchanged than the experiment results. Could someone advice me on preferred models?
Example of Helxchanger (helical baffle heat exchanger) http://www.sciencedirect.com/science...29549316000686 |
heat exchanger, helical baffle hx, helixchanger |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
who work with Heat exchanger model? | mariam.sara | Fluent Multiphase | 0 | July 2, 2015 14:52 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
How to use Heat Exchanger model? | Johnny | FLUENT | 0 | August 9, 2004 07:44 |
