Rotating mesh simulation in Simscale using an imported mesh
Old   May 27, 2021, 12:03
Default Rotating mesh simulation in Simscale using an imported mesh
Luis Mayz
lmayz is on a distinguished road
Does anyone made a simulation in Simscale using a rotating mesh but did not generate that mesh in Simscale instead of uploading it from OpenFoam or in other format?
My problem is that I want to simulate a wind turbine (HAWT) using the rotating mesh approach. I generated a mesh in ANSYS Meshing instead of snappyHexmesh because ANSYS is easier to control de refinements that I want near the blades. I imported the mesh to OpenFoam using FluentMeshToFoam and even run a few seconds of the transient simulation using PIMPLE solver. The problem is when I upload the mesh to Simscale. It recognize two regions of the mesh (the moving part and the static one), I assign AMI rotating zone condition to one region and specify air as material for the static region. Then, when I try to run, it shows me an error claiming that one region has no assigned material, so I assign air as material to both regions. Now the error changes claiming that for this simulation only flow region can have an assigned material.
If anyone did a similar simulation with an imported mesh in Simscale I would appreciate an advice. I wrote in the Simscale official forum but it was not helpful and searched in other forums but no much is talked about Simscale.
Thanks
PD: I attached pictures of the errors and this is the link of the project in Simscale
https://www.simscale.com/workbench/?...s%2Ffluids%2F0
lmayz is offline   Reply With Quote
Old   February 16, 2023, 11:39
Steve Lainé
slaine is on a distinguished road
Thanks
Hi, did you apply a rotating zone to the body 'rotatingZone' under Advanced Concepts? There is a new solver in SimScale that would be better suited to this problem: Subsonic.
slaine is offline   Reply With Quote
imported mesh, rotating mesh, simscale
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
simulation of a rotating stirred tank using mesh motion vavnoon FLUENT 0 July 6, 2020 08:12
Rotating Mesh - Mesh Overlap/Discontinuity At Boundary Interface sai95kamal FLUENT 1 June 15, 2020 09:58
Mesh replacement in sub-domains while cfx simulation is in progress chiragsvnit CFX 4 December 11, 2015 13:25
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
