Questions about FLACS
Old   May 25, 2021, 09:50
Question Questions about FLACS
LT
NewKid is on a distinguished road
Dear all,
I run into two big problems while I try to virtualize the mesh and the the solved data with FLACS V9.0 by myself。 Problem I: How to read the face, cell information in FLACS case? Although I have read the X axis point location, Y axis point location and z axis point location, but the cgxxx.dat3(Grid), cmxxx.dat3(Polygons) and coxxx.dat3(Geometry) are all in binary format. Till now, it seems no way has been found to read these data, or expose the data in ASCII format.
Probelem II: How to read the solved data, like temperature field, pressure field in r1xxxx.dat3 and r3xxx.dat3 which are in binary format. I must read the field value to render the model in my software. The last little problem is that ir1xxxx.dat3 or r3xxxx.dat3 contains steady data or transient data, or up to the case?
Any suggestion or clue or method or idea is welcome.
Thanks in advance!
Best regards!
NewKid is offline   Reply With Quote
data, flacs, mesh
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
General questions about how to mesh and build up my case ThunderstruckGER OpenFOAM 5 September 23, 2018 19:33
possible interview questions atturh Main CFD Forum 1 February 21, 2012 09:53
NACA0012 Validation Case Questions ozzythewise Main CFD Forum 3 August 3, 2010 15:39
Visualization tool for FLACS files Rijad Main CFD Forum 0 July 27, 2007 10:28
