May 20, 2021, 02:24 |
bison and m4 not getting built for swak4Foam
Supratim
I have tried to build the correct versions of dependencies m4 and bison for installing swak4Foam but for some reason both of these show errors while executing the make command. I am using OpenFOAM version 2012 in Ubuntu 20.04. And I have m4 version 1.4.18 already installed in the system but the one required to be built is 1.4.17. And the version of bison required is 2.7.
The error encountered after the make command of m4: gcc -I. -g -O2 -MT freadahead.o -MD -MP -MF $depbase.Tpo -c -o freadahead.o freadahead.c &&\ mv -f $depbase.Tpo $depbase.Po freadahead.c: In function 'freadahead': freadahead.c:91:3: error: #error "Please port gnulib freadahead.c to your platform! Look at the definition of fflush, fread, ungetc on your system, then report this to bug-gnulib." 91 | #error "Please port gnulib freadahead.c to your platform! Look at the definition of fflush, fread, ungetc on your system, then report this to bug-gnulib." | ^~~~~ make[3]: *** [Makefile:1837: freadahead.o] Error 1 make[3]: Leaving directory '/home/supratim/OpenFOAM/supratim-v2012/swak4Foam/m4-1.4.17/lib' make[2]: *** [Makefile:1602: all] Error 2 make[2]: Leaving directory '/home/supratim/OpenFOAM/supratim-v2012/swak4Foam/m4-1.4.17/lib' make[1]: *** [Makefile:1506: all-recursive] Error 1 make[1]: Leaving directory '/home/supratim/OpenFOAM/supratim-v2012/swak4Foam/m4-1.4.17' make: *** [Makefile:1461: all] Error 2 The error encountered after make command for bison: fseterr.c: In function 'fseterr': fseterr.c:77:3: error: #error "Please port gnulib fseterr.c to your platform! Look at the definitions of ferror and clearerr on your system, then report this to bug-gnulib." 77 | #error "Please port gnulib fseterr.c to your platform! Look at the definitions of ferror and clearerr on your system, then report this to bug-gnulib." | ^~~~~ make[3]: *** [Makefile:1895: fseterr.o] Error 1 make[3]: Leaving directory '/home/supratim/OpenFOAM/supratim-v2012/swak4Foam/bison-2.7/lib' make[2]: *** [Makefile:1651: all] Error 2 make[2]: Leaving directory '/home/supratim/OpenFOAM/supratim-v2012/swak4Foam/bison-2.7/lib' make[1]: *** [Makefile:1532: all-recursive] Error 1 make[1]: Leaving directory '/home/supratim/OpenFOAM/supratim-v2012/swak4Foam/bison-2.7' make: *** [Makefile:1462: all] Error 2 Can somebody please help me out regarding this? Thanks and regards |
May 16, 2022, 13:22 |
Mohammad Reza
Rep Power: 11 |
I am facing the same problem, have you found any solution? |
August 10, 2023, 05:39 |
#3 | |
p.t
I found a solution in https://code.videolan.org/videolan/vlc/-/issues/28048, according to which I modified the fseterr.c L32 to Code:
#if defined _IO_EOF_SEEN || __GNU_LIBRARY__ == 1 Hope it helps. |
