How to calculate pressure head for radial pump (turbulent flow)? |
May 12, 2021, 13:58 |
Abhishek
Rep Power: 6 |
Can I calculate pressure head of radial pump (turbulent flow) with the help of Bernoulli equation?
I have a radial pump (one input one output) for which I know rotational speed, and inlet mass flow rate (in short I know boundary condition, CFD simulation is also successfully carried out). Now usually a pressure head between this two point 1 and 2 can be calculated according to Bernoulli's equation e.g. Pressure Head = (P2/Rho*g)-(P1/Rho*g)+(((v2)^2)-(v1^2))/2*g) Now the real question is Bernoulli equation can be applied for laminar flow along streamline right?. In my case flow in the centrifuge is turbulent, and I am still using the above mentioned equation to calculate pressure head. Am I violating this principle? Last edited by AbhishekShingalaCFD; May 12, 2021 at 16:49. |
May 12, 2021, 16:07 |
Lucky
Rep Power: 66 |
Can you describe more what is the context? What are the knowns?
Is this even a CFD related question or do you have a black box? |
May 19, 2021, 15:19 |
Abhishek
Rep Power: 6 |
Yes this is CFD related question. I know rotational speed, Inlet mass flow rate and Outlet mass flow rate. I am calculating pressure and velocities at outlet and inlet with the help of cfd to calculate develop pressure head.
May 19, 2021, 18:21 |
Lucky
Rep Power: 66 |
Bernoulli's equation is only for streamlines and has a lot of limitations, yes.
But there is a correct equation called the Mechanical Energy Balance equation, it looks almost exactly like Bernoulli's but it has the head losses in it which is how we define pressure head in the first place. Last edited by LuckyTran; May 20, 2021 at 00:09. |
pressure head, pump, turbulent flow |
Simple Box - Gravity with Pressure Outlet - Unrealistic Reverse Flow | pyccknn | FLUENT | 2 | December 1, 2021 18:31 |
Calculate Mass Flowrate and Mass Flow Averaged Total Pressure at inlet and outlet | coolcrasher | OpenFOAM Post-Processing | 7 | November 4, 2021 05:57 |
How to calculate Reynolds shear stress of a fully turbulent channel flow | yansheng | STAR-CCM+ | 1 | March 8, 2016 18:35 |
Problem with SIMPLEC-like finite volume channel flow boundary conditions | ghobold | Main CFD Forum | 3 | June 15, 2015 12:14 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
