Rotating pipe to jet impingement
Old   May 11, 2021, 23:43
Smile Rotating pipe to jet impingement
Mauro Killary
maurokillary13 is on a distinguished road
Hi to everyone! i'm trying to select a correct approach to simulate a rotating pipe with a specific swirl numbers, in my real configuration there is a pipe rotating and then the flow (air and water) is entrained as a jet impingment to a flat plate at 90°. Also my model need to be in 3D this is order to evaluate erosion with DPM (Fluent).
i have a doubt it will be right to perform a cfd analysis of the 3d rotaing pipe (steady analysis) and then use this outlet condition to inital conditions for a short pipe (flow whole developed) and the distance to flat plate (transient analysis)?
Or it will be better to perfom the whole system.
i hear and reply any question about my cfd model
a lot of thanks !
maurokillary13 is offline   Reply With Quote
air flow simulation, ansys fluent, jet impingment, swirling flow, transient 3d
compressibleInterFoam - Jet Impingement BCs vigges OpenFOAM Running, Solving & CFD 2 June 14, 2020 23:23
Rotating pipe analysis hamed.majeed FLUENT 4 October 29, 2018 09:18
Velocity Profile for Cureved surface Jet Array Impingement Case ara STAR-CCM+ 4 February 4, 2015 06:24
Best Turbulence Model for Heat Transfer in Jet Impingement ara STAR-CCM+ 5 July 25, 2014 12:45
Jet impingement on cylindrical obstacles robmuggleton FLUENT 1 October 21, 2013 19:08
