VOF simulation in FLUENT
Old   May 9, 2021, 12:04
Default VOF simulation in FLUENT
Alex
Kerouac is on a distinguished road
Hi everyone,
I'm trying to perform a VOF 2D analysis in Fluent, but I found some problems; my simulation is not converging. I'm trying to simulate the deposition of a material (ABS) on a moving plate; the other phase is air at constant density & viscosity.
The simulation gives no problem until the red fluid (ABS, in file attach-1) is still moving towards the bottom edge in the domain. Here there's the moving wall and simulation does not converge.
Simulation is performed by mean of Implicit solver; max. Courant number of 0.4; variable time step width (also, same problem if I use a lower courant number and a lower time step); interface anti-diffusion and implicit formulation for body force terms.
Under-relaxation factors are half the default values.
I am attaching some screens in order to be more clear.
Boundary conditions are:
-inlet of ABS phase from the upper edge (non-newtonian power-law)
-wall (no slip) on the two side edges of the vertical region (filled with red phase in attach-1 file)
-wall (with no slip and moving at 0.02[m/s] in horizontal direction); this is the bottom edge in the domain
-pressure outlet: all remaining edges (the problem is the same if I use Outflow boundary condition)
The same problem, obviously, appears when I perform 3D simulation; because of the great amount of computational effort requested by 3D, I turned to 2D, finding the same problem.
I will appreciate your help in finding a possible solution to this problem,
Kerouac
Kerouac is offline   Reply With Quote
fluent, implicit method, non newtonian power law, vof
CFD simulation of gas cicrcuit breaker in fluent with dynamic meshing. Mahesh7238 FLUENT 1 April 5, 2021 01:21
Start new Ansys Fluent Simulation automatically Malue Fluent UDF and Scheme Programming 1 October 4, 2017 02:48
Which Multiphase Model Should be selected in Fluent for my below described simulation oberstar Fluent Multiphase 0 September 28, 2017 13:05
Courant number alert/pause simulation in fluent 2d aarratia FLUENT 1 April 16, 2015 03:07
Problem with VOF in fluent ash-khan FLUENT 2 November 3, 2009 03:00
