Boundary condition for the integral length scale
Old   April 30, 2021, 04:32
Wink Boundary condition for the integral length scale
Turbulence
TurbulenceTaxes is on a distinguished road
Hello, turbulence geniuses,
What should be the appropriate assumption for the boundary condition for the integral length scale at the wall? And are there any physical explanations for that boundary condition?
It is an urgent question and thanks a lot for answering.
TurbulenceTaxes is offline   Reply With Quote
Old   April 30, 2021, 16:30
Kira
aero_head is on a distinguished road
It depends on your slip length.
The no-slip boundary condition or no-velocity-offset boundary condition assumes that the speed of the fluid layer in direct contact with the boundary is identical to the velocity of this boundary. There is no relative movement between the boundary and this fluid layer, therefore there is no slip. The slip boundary condition or velocity-offset boundary condition assumes a discontinuity in the velocity function, i.e., a relative movement between the fluid and the boundary, therefore there is slip. The hypothetical distance inside of the boundary at which the velocity function would effectively reach the velocity of the boundary is referred to as slip length Ls. Ls is the ratio of the coefficient of viscosity (m) to the coefficient of slip (Cs).
The Knudsen number allows a rough numerical approximation of when to use which condition (i.e. no slip or slip). In general, the no-slip boundary condition can be applied in most applications in microfluidics when dealing with solid boundaries and incompressible fluids at characteristic length scales above 300 nm.
aero_head is offline   Reply With Quote
boundary condtitions, integral length scale
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Relation between integral time and integral length scale kepler123 Main CFD Forum 6 January 25, 2019 18:01
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 07:49
