FloEFD Condensation Simulation - Please help!
Old   April 29, 2021, 07:48
Default FloEFD Condensation Simulation - Please help!
Cameron
cattewell is on a distinguished road
Hi all,
I'm really struggling to perform a condensation clearing simulation using FloEFD. I'm trying to a simulation similar to this YouTube video - but it's not explained how it is set up!
https://www.youtube.com/watch?v=MD4Hnj4dXKQ&t=18s
I'm simulating a vehicle lamp, and I've applied a film condition of 0.25mm on the three inside surfaces of the lens.
When it is simulating I've been monitoring two global goals - Max and min film thickness. What I've been seeing happen is the film starts to thin in some places, but thickens to unbelievable numbers in some places before failing. Generally it reaches around 1000 micrometers but once I had it up at 10^6 micrometers! It just tends to come up with the error that it failed and suggests contacting FloEFD support. We don't have a current contract with them so can't ask them for support.
If there's any of my settings you would like to know then I'd be happy to provide them - but here's just a few I thought might help.
Fluid film thickness = 250 micrometers
Humidity = 25%
Ambient temperature 15 degrees - although the rear of the lamp is in a heat source fixed at 90 degrees.
The lamp is sealed but there is a gore patch where I have applied a boundary condition fixing the pressure and humidity.
If you could help at all it would be amazing as I'm at a loss to what to try next!
Thanks so much!
Paul
cattewell is offline   Reply With Quote
film condensation, floefd.v5
FLUENT - EVAPORATION and CONDENSATION SIMULATION Patryk FLUENT 18 September 27, 2020 10:23
Mixture Model with Condensation and Evaporation on Vertical Wall gartz89 FLUENT 3 March 20, 2020 10:16
restarting paused transient simulation using reactingFoam JMDag2004 OpenFOAM Running, Solving & CFD 1 August 10, 2015 11:15
Fluent Vs Solid-works Flow Simulation Mortezab Main CFD Forum 16 July 5, 2013 03:47
Condensation simulation? Gregor Kotnik Main CFD Forum 4 May 2, 2000 17:13
