what does negative moment means in ansys fluent?
Old   April 5, 2021, 06:13
Default what does negative moment means in ansys fluent?
sumit
sumit_vjti is on a distinguished road
I am working on savonius turbine which is a Vertical Axis Wind turbine. I have used dynamic mesh method for this. I am getting constant rpm after some iteration and moment is in cyclic variation(fig attached below). I want to know why I am getting -ve moment values ,while rotor is rotating in anticlockwise direction in the entire simulation.
sumit_vjti is offline   Reply With Quote
cfd, savonius rotor, vawt wind turbine, wind-turbine
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 04:34
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
2-way FSI in Ansys CFX 15 LucasGasparino CFX 3 August 6, 2015 04:17
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 11:54
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
