Error with UDF in Fluent - UDF for parabolic developed velocity profile.
Old   April 4, 2021, 11:11
Exclamation Error with UDF in Fluent - UDF for parabolic developed velocity profile.
Arun Prasath M
Arun_Prasath_M is on a distinguished road
Hello there,
I want to give a developed velocity profile at an inlet through a UDF for my problem. I'm using ANSYS 19.2 version and I couldn't find an option to enter expressions directly. So, I've written an UDF function which is supposed to provided a developed velocity profile at inlet instead of a uniform one.
I'm not successful. I'm getting errors. I'm attaching all the necessary details. I need help. Please, go through the UDF code and the formula i'm using. Please, let me know if I'm doing anything wrong.
Thanks.
This is the formula I'm using for developed parabolic velocity at inlet. I found it through a tutorial. (https://youtu.be/LF06grv299A?t=449).
Please, Let me know If I'm using wrong formula. Please, give me some more information for this formula.
v = v_max*[1-((x^2 + y^2)/R^2)] (Image is also attached)
Where R = Radius of the pipe
r = Distance from the central axis
UDF Code
vprofile.c
#include "udf.h"
DEFINE_PROFILE(inlet_x_velocity, thread, position)
  real x[ND_ND];
  real y;
  face_t f;
  begin_f_loop(f,thread)
    F_CENTROID(x, f, thread);
    F_PROFILE(f, thread, position) = 2.53*(1-((x*x+y*y)/(0.00775*0.00775)));
  end_f_loop(f, thread)
Error
Attached...
cpp -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/main" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/addon-wrapper" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/io" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/species" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/pbns" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/numerics" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/sphysics" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/storage" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/mphase" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/bc" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/models" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/material" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/amg" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/util" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/mesh" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/udf" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/ht" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/dx" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/turbulence" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/parallel" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/etc" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/ue" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/dpm" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/dbns" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/tgrid/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/PRIME/tgrid/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/cortex/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/client/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/multiport/src" -I. -DUDFCONFIG_H="<udfconfig-host.h>" "D:/Ansys pro/Agarwal et al/Test UDF/vprofile_new.c"
Error: D:/Ansys pro/Agarwal et al/Test UDF/vprofile_new.c: line 18: parse error.
cpp -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/main" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/addon-wrapper" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/io" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/species" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/pbns" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/numerics" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/sphysics" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/storage" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/mphase" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/bc" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/models" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/material" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/amg" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/util" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/mesh" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/udf" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/ht" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/dx" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/turbulence" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/parallel" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/etc" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/ue" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/dpm" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/dbns" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/tgrid/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/PRIME/tgrid/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/cortex/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/client/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/multiport/src" -I. -DUDFCONFIG_H="<C:/Users/SRM/AppData/Local/Temp/udfconfig-11380-node0.h>" "C:/Users/SRM/AppData/Local/Temp/vprofile_new.c.11380.0.c"
Error: C:/Users/SRM/AppData/Local/Temp/vprofile_new.c.11380.0.c: line 18: parse error.
cpp -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/main" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/addon-wrapper" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/io" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/species" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/pbns" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/numerics" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/sphysics" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/storage" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/mphase" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/bc" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/models" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/material" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/amg" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/util" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/mesh" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/udf" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/ht" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/dx" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/turbulence" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/parallel" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/etc" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/ue" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/dpm" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/dbns" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/tgrid/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/PRIME/tgrid/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/cortex/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/client/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/multiport/src" -I. -DUDFCONFIG_H="<C:/Users/SRM/AppData/Local/Temp/udfconfig-968-node1.h>" "C:/Users/SRM/AppData/Local/Temp/vprofile_new.c.968.1.c"
Error: C:/Users/SRM/AppData/Local/Temp/vprofile_new.c.968.1.c: line 18: parse error.
cpp -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/main" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/addon-wrapper" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/io" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/species" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/pbns" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/numerics" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/sphysics" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/storage" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/mphase" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/bc" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/models" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/material" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/amg" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/util" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/mesh" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/udf" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/ht" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/dx" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/turbulence" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/parallel" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/etc" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/ue" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/dpm" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/dbns" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/tgrid/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/PRIME/tgrid/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/cortex/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/client/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/multiport/src" -I. -DUDFCONFIG_H="<C:/Users/SRM/AppData/Local/Temp/udfconfig-3432-node2.h>" "C:/Users/SRM/AppData/Local/Temp/vprofile_new.c.3432.2.c"
Error: C:/Users/SRM/AppData/Local/Temp/vprofile_new.c.3432.2.c: line 18: parse error.
cpp -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/main" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/addon-wrapper" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/io" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/species" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/pbns" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/numerics" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/sphysics" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/storage" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/mphase" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/bc" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/models" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/material" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/amg" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/util" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/mesh" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/udf" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/ht" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/dx" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/turbulence" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/parallel" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/etc" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/ue" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/dpm" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/src/dbns" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/tgrid/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/PRIME/tgrid/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/cortex/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/client/src" -I"C:\PROGRA~1\ANSYSI~1\v192\fluent\fluent19.2.0/multiport/src" -I. -DUDFCONFIG_H="<C:/Users/SRM/AppData/Local/Temp/udfconfig-12804-node3.h>" "C:/Users/SRM/AppData/Local/Temp/vprofile_new.c.12804.3.c"
Error: C:/Users/SRM/AppData/Local/Temp/vprofile_new.c.12804.3.c: line 18: parse error.
File Type: c vprofile_new.c (456 Bytes, 5 views)
Last edited by Arun_Prasath_M; April 4, 2021 at 11:21. Reason: added an image reference
Arun_Prasath_M is offline   Reply With Quote
Old   October 20, 2022, 21:46
Demetrio Pérez Vigueras
Demetrio Pérez Vigueras is on a distinguished road
Originally Posted by Arun_Prasath_M View Post
Hello there,
Thanks.
UDF Code
vprofile.c
#include "udf.h"
  real x[ND_ND];
  real y;
  face_t f;
Error
Attached...
Remember that x is a vector where the coordinates of the centroid of the face are stored, that is, x=x[0], y=y[0], z=z[0].
If in F_PROFILE(f, thread, position) = 2.53*(1-((x*x+y*y)/(0.00775*0.00775)));
want to use the x and y coordinates, then get them from the vector x by
x=x[0], y=y[0].
#include "udf.h"
real cen[ND_ND];
real x,y,z;
face_t f;
F_CENTROID(cen, f, thread);
x=cen[0];
y=cen[1];
z=cen[2];
Demetrio Pérez Vigueras is offline   Reply With Quote
fluent - udf, parabolic profile, parabolic velocity, udf and programming
UDF for inlet velocity profile Bollonga Fluent UDF and Scheme Programming 4 June 29, 2021 05:40
UDF - Inlet Velocity Profile (Ansys Fluent) vinayak4399 Fluent UDF and Scheme Programming 3 August 25, 2020 15:15
Velocity profile reading in Fluent mkpm FLUENT 0 July 28, 2016 03:12
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 20:08
Patch fully developed velocity and turbulence profile over full domain Teumde FLUENT 2 June 29, 2015 14:47
