how to rectify the error for flow around a cylinder:Arc error |
April 3, 2021, 14:37 |
manish
Rep Power: 7 |
From void Foam::blockEdges::arcEdge::calcFromMidPoint(const point&, const point&, const point&)
in file blockEdges/arcEdge/arcEdge.C at line 66. Please find below the blockMeshDict file. Please let me know where I am doing wrong * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.1; vertices ( // pre-block -0.5<z<0.5 (-4 -1.5 0.5)// vertex 0 (-2 -1.5 0.5)// vertex 1 (-2 -1.5 -0.5)// vertex 2 (-4 -1.5 -0.5) // vertex 3 (-4 1.5 0.5)// vertex 4 (-2 1.5 -0.5)// vertex 5 (-2 1.5 -0.5) //vertex 6 (-4 1.5 -0.5)// vertex 7 // obstacle blocks // bottom (-2 -1.5 0.5)//vertex 8 (-2 -1.5 -0.5)//vertex 9 (-0.212725 -0.212725 0.5)//vertex10 (0.212725 -0.212725 0.5)//vertex11 (0.212725 -0.212725 -0.5)//vertex12 (-0.212725 -0.212725 -0.5) //vertex13 // left (-0.212725 -0.212725 0.5)// vertex 14 (-0.212725 0.212725 -0.5)// vertex 15 // top (0.212725 0.212725 0.5)// vertex 16 (0.212725 0.212725 -0.5)// vertex 17 (2 1.5 0.5)// vertex 18 (2 1.5 -0.5) // vertex 19 // right // all the vertices are already defined // post-block (8 -1.5 0.5)// vertex 20 (8 -1.5 -0.5) // vertex 21 (8 1.5 0.5)// vertex 22 (8 1.5 -0.5)// vertex 23 ); blocks ( // pre-block hex ( 0 1 2 3 4 5 6 7) ( 60 1 30) simpleGrading (1 1 1) // obstacle blocks hex ( 1 8 9 2 10 11 12 13) ( 30 1 30) simpleGrading (1 1 1) // bottom hex ( 1 10 13 2 5 14 15 6) ( 30 1 30) simpleGrading (1 1 1) // left hex (14 16 17 15 5 18 19 6) ( 30 1 30) simpleGrading (1 1 1) // top hex (11 8 9 12 16 18 19 17) ( 30 1 30) simpleGrading (1 1 1) // right // post-block hex ( 8 20 21 9 18 22 23 19) (180 1 30) simpleGrading (1 1 1) ); edges ( arc 10 11 ( 0 -0.25 0.5) arc 12 13 ( 0 -0.25 -0.5) arc 14 10 (-0.25 0 0.5) arc 15 13 (-0.25 0 -0.5) arc 14 16 ( 0 0.25 0.5) arc 15 17 ( 0 0.25 -0.5) arc 16 11 ( 0.25 0 0.5) arc 17 12 ( 0.25 0 -0.5) ); boundary ( inlet { type patch; faces ( ( 0 4 7 3) ); } outlet { type patch; faces ( (20 21 23 22) ); } wall { type wall; faces ( ( 4 5 6 7) ( 5 18 19 6) (18 22 23 19) ( 0 1 2 3) ( 1 8 9 2) ( 8 20 21 9) ); } obstacle { type wall; faces ( (10 11 12 13) (11 16 17 12) (14 16 17 15) (10 14 15 13) ); } frontAndBack { type empty; faces ( ( 0 1 5 4) ( 1 10 14 5) (14 16 18 5) (11 8 18 16) ( 1 8 11 10) ( 8 20 22 18) ( 3 7 6 2) ( 2 6 15 13) (15 6 19 17) (12 17 19 9) ( 2 13 12 9) ( 9 19 23 21) ); } ); mergePatchPairs ( ); // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 07:35 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 10:17 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 21:30 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
