April 2, 2021, 06:17 |
Sharp trailing edge
Vangelis
I'm trying to create unstructured mesh of a 3d aircraft wing with ANSYS meshing.
When I use inflation layers (First Layer Thickness) the meshing quality drops and I can barely increase the minimum orthogonal quality from 0,06 and decrease skewness from 0,94 in the area of the sharp trailing edge. I've used body of incluence around the wing and increase the refinement of mesh but I only get the same or worse results. My number of elements is about 2-3 millions and I do not want to exceed this number. Furthermore, the geometry of the wing has to be the same as the original, so it is forbidden any radius fillet in the trailing edge. Can anyone give me a tip what to do? Any help will be important. |
April 2, 2021, 10:47 |
Kira
Rep Power: 8 |
It would help to include a photo of your mesh, and show the bad quality elements.
April 5, 2021, 06:39 |
Photo of low quality elements
Vangelis
Here is a capture of the low quality elements in the trailing edge of the wing.
3d wing, ansys meshing, orthogonal quality, sharp trailing edge, skewness |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
How to deal with prism layers in sharp trailing edge of the airfoil | Rinia | STAR-CCM+ | 1 | March 11, 2019 20:25 |
[ICEM] Meshing Wing with low Y+ value and sharp trailing edge | sonic109 | ANSYS Meshing & Geometry | 0 | July 27, 2015 09:29 |
[ICEM] Hole near sharp trailing edge of airplane/wing geometry | jlichtwa | ANSYS Meshing & Geometry | 2 | September 21, 2010 15:19 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
