hePsiThermo Floating point exception
Old   March 18, 2021, 07:44
Default hePsiThermo Floating point exception
Vinzenz Götz
Vinzmann is on a distinguished road
When I try my simulation, no matter the solver, I always encounter this floating point exception:
diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0
[0] #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
[0] #1 Foam::sigFpe::sigHandler(int) at ??:?
[0] #2 ? in "/lib64/libc.so.6"
[0] #3 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam:: species::thermo<Foam::hConstThermo<Foam:erfectGa s<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:?
[0] #4 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam:: species::thermo<Foam::hConstThermo<Foam:erfectGa s<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:?
[0] #5 ? at ??:?
[0] #6 __libc_start_main in "/lib64/libc.so.6"
[0] #7 ?[m2326-17-02:19128] *** Process received signal ***
[m2326-17-02:19128] Signal: Floating point exception (8)
[m2326-17-02:19128] Signal code: (-6)
[m2326-17-02:19128] Failing at address: 0x11df7f0b00004ab8
at ??:?
[m2326-17-02:19128] [ 0] /lib64/libc.so.6(+0x36400)[0x7fc5293ee400]
[m2326-17-02:19128] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x7fc5293ee387]
[m2326-17-02:19128] [ 2] /lib64/libc.so.6(+0x36400)[0x7fc5293ee400]
[m2326-17-02:19128] [ 3] /opt/OpenFOAM/OpenFOAM-8/platforms/linux64GccDPInt64Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThe rmoINS_9psiThermoENS_11pureMixtureINS_19sutherland TransportINS_7species6thermoINS_12hConstThermoINS_ 10perfectGasINS_6specieEEEEENS_22sensibleInternalE nergyEEEEEEEE9calculateEv+0x1de)[0x7fc52ce0666e]
[m2326-17-02:19128] [ 4] /opt/OpenFOAM/OpenFOAM-8/platforms/linux64GccDPInt64Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThe rmoINS_9psiThermoENS_11pureMixtureINS_19sutherland TransportINS_7species6thermoINS_12hConstThermoINS_ 10perfectGasINS_6specieEEEEENS_22sensibleInternalE nergyEEEEEEEE7correctEv+0x2a)[0x7fc52ce946fa]
[m2326-17-02:19128] [ 5] rhoCentralFoam[0x4312e8]
[m2326-17-02:19128] [ 6] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7fc5293da555]
[m2326-17-02:19128] [ 7] rhoCentralFoam[0x435adb]
[m2326-17-02:19128] *** End of error message ***
mpirun noticed that process rank 0 with PID 0 on node m2326-17-02 exited on signal 8 (Floating point exception).
I don't know where to look or what screws to turn anymore. Could you help me decipher this? I already read that this comes down to deviding by zero most of the time but where and how do I fix this?
Vinzmann is offline   Reply With Quote
icoFoam floating point exception (8) leizhao512 OpenFOAM Running, Solving & CFD 7 November 1, 2018 12:43
A floating point exception has occurred: floating point exception [Overflow]. starlight STAR-CCM+ 4 May 4, 2016 10:08
A floating point exception - SEM Model yansheng STAR-CCM+ 1 April 4, 2016 05:57
Floating point exception from twoPhaseEulerFoam openfoammaofnepo OpenFOAM Running, Solving & CFD 1 March 19, 2016 14:56
Floating point exception (core dumped) for GAMG solver yuhou1989 OpenFOAM Running, Solving & CFD 2 March 24, 2015 20:28
