Trailing edge separation pocket: physical or numerical? |
Marco Caboni
Rep Power: 0 ![]() |
Hi all,
Recently, I have been performing steady state, incompressible simulations using the k-omega SST RANS turbulence model on a wind turbine blade. For this blade, I have generated 2 grids which use the same number of chordwise points, but one of them uses 3-time larger number of spanwise points (see screenshot). The simulation done using the finer mesh exhibits a large trailing edge separation pocket (see screenshot) in a region where we wouldn’t normally expect separation to occur (very low AoA and no sudden variations of the blade’s planform). I have also noticed several much smaller pockets occurring in the finer mesh over the whole training edge of the blade. Using the coarser mesh most of the separation pockets (including the large one) disappear. For the finer mesh, average residuals look fine, and field residuals do not indicate any grid-related issues around the pocket region. Also, the flow field around the pocket does not look abnormal. This is puzzling as I cannot conclude whether these pockets are physical (captured by a finer mesh) or just numerical artifacts. Have you ever experienced anything similar? Or can you suggest possible tests or references to shed some light on the issue? Many thanks! Last edited by MarcoCaboni; March 11, 2021 at 13:59. |
lucas s
Rep Power: 13 ![]() |
Coarser mesh leads to higher numerical dissipation. So it is not surprising to observe separation as the mesh is finer. However in your case, I would have expected to observe that while increasing the number of nodes chordwise. It is true that the separation is 3D and the span direction should have an impact on the separation. I suggest you study the mesh convergence in all directions. And I think you can find many articles with similar issues on naca profiles. Cheers, Lucas |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
First of all, you should ensure that the residuals of all equations on the finer grid are below a good threshold. Then try to refine further the grid in all directions. Note that to assess the physical meaning of a flow separation you need to have a fine resolution in the BL.
fine meshes, rans, separation |
Discontinuity at the blunt trailing edge of an airfoil | klkl | OpenFOAM Running, Solving & CFD | 0 | October 28, 2020 04:42 |
Trailing edge sensitivity anlaysis | JanH | SU2 | 2 | November 23, 2018 13:53 |
Difference between diffusion, dissipation and dispersion in physical and numerical | TurbJet | Main CFD Forum | 9 | October 6, 2018 18:15 |
Meshing near leading and trailing edge of propeller | surajp92 | STAR-CCM+ | 1 | June 1, 2017 01:40 |
[ICEM] Meshing Wing with low Y+ value and sharp trailing edge | sonic109 | ANSYS Meshing & Geometry | 0 | July 27, 2015 09:29 |
