How to Merge faces and split domain in ScFlow
Old   February 14, 2021, 17:11
Default How to Merge faces and split domain in ScFlow
Mohammadreza Khodadadi
RezaDizaji is on a distinguished road
Hello, I am quite new in ScFlow (Cradle) software. I would like to simulate rotating shaft lubrication (see extracted fluid region in attach). I have imported shaft (and end cap and bolt), then have extracted fluid domain,
1) there are a lot of faces and I would like to merge them.
2) I would like to split domain in location of red line (V1: fix and V2:rotates) to use discontinues mesh analysis. I didnt find documents that could help me.
Can somebody give a tip/support please?
RezaDizaji is offline   Reply With Quote
Old   September 1, 2021, 09:59
Guvennergiz's Avatar
Guven Nergiz
Guvennergiz is on a distinguished road
Dear Reza,
In the Kicker, there is a blue book which consist all information that you need to know about Cradle. If you want to analyze rotating parts, you should check "Training 3" which is under the Operation section. Also you dont need to merge these faces, they are not a problem for Cradle. You can use Cross Section (Solid) command to split solids with axis, after that you can unite other solids back. It is easy in this way.
I hope it helps you.
Guvennergiz is offline   Reply With Quote
cradle, domain, faces, scflow
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
[Other] 2D adaptive Mesh Refinement baco OpenFOAM Community Contributions 80 August 14, 2022 15:18
[snappyHexMesh] snappyHexMesh stuck when snap is turned on yukuns OpenFOAM Meshing & Mesh Conversion 3 February 2, 2021 14:05
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) AndreP STAR-CCM+ 10 August 2, 2018 08:48
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
