Floating Point Error when using density based solver |
February 10, 2021, 11:54 |
Sagar Shah
Rep Power: 5 |
Hi Everyone,
Firstly to give some context, I am trying to analyse flow around a projectile at supersonic and hypersonic speeds. However when using the density based solver I get a floating point error after 5-9 iterations of the simulation. My aim is to replicate the results obtained for the parabolic projectile in this paper for a fineness ratio of 4. https://www.researchgate.net/publica...parative_study So I have selected a projectile/nosecone base length of 0.15 m and a length of 0.6 m. Simulation Parameters & Stats Mesh Stats: Average Orthogonality Quality = 0.99234 Average Skewness = 3.5288e-002 Average Element Quality = 0.67444 Total Elements = 204428 Bounding Box Diagonal = 1.9071 m Solver Setup: Fluid - Air Ideal Gas at Sea Level Inlet - Velocity inlet Outlet - Pressure Outlet Axisymmetric symmetry Solver - Density Turbulence Model - Spalart-Allamaras (1 eqn) Analysis Type - Steady State Please let me know if there's anything I've missed out which would help you advise me on what I can do to ensure my simulation doesn't keep erroring out. Thanks for your help in advance |
Pressure based and Density based Solver | Xobile | Main CFD Forum | 39 | August 19, 2020 07:04 |
Using Density Gradient C_R_G(c,t), Pressure Based Solver | Anirudh_Deodhar | Fluent UDF and Scheme Programming | 1 | October 25, 2013 06:43 |
Pressure based vs density based solver | newbie384 | FLUENT | 2 | July 5, 2013 03:04 |
[blockMesh] error EOF in blockMesh | Ahmed Khattab | OpenFOAM Meshing & Mesh Conversion | 7 | May 17, 2012 01:37 |
Density based solver, Chemkin, Stiff combustion | mahmohammad | FLUENT | 0 | April 20, 2012 14:37 |
