February 5, 2021, 07:49 |
CFD, pressure data problem, spectra analysis
xin xiong
Rep Power: 5 |
Hi guys! I have to transfer the pressure data in time domain but I have an issue. So, I have 149999 data of pressure versus time , which is discrete data. I also have a frequency versus SPL data, which has 206 in number. i want to sampling that pressure data with 3kHz low-pass filter, which have same number of data with the latter data, with which i can compare it with the frequency data. I need to do the spectra analysis of the CFD result, so I have transferred time to frequency. After I transferred the time domain into frequency, then calculate the sound pressure level, but there is a difference between the CFD and experiment result- of 60db. Can someone pls help me identify why there is this difference of 60db because i have no idea about it... Thanks in advance. If you can offer any sort of advise or guidance - DM me or comment here, if you don't mind having a look at the data real quick
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times | vidyadhar | ParaView | 9 | May 20, 2020 20:06 |
CFD analysis of a heat transfer problem | vinitraj3 | Main CFD Forum | 0 | May 2, 2015 05:35 |
CFD Online Celebrates 20 Years Online | jola | Site News & Announcements | 22 | January 31, 2015 00:30 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 14:06 |
Radial Turbine Analysis B.C Problem | yjs1027 | FLUENT | 0 | April 18, 2013 03:06 |
