how to permanently initialize the flow field or automate the initialization process |
January 29, 2021, 13:58 |
Rep Power: 13 |
I am coupling Design Optimization with ANSYS Fluent in Workbench 2020 R2. I can do the analysis. I am patching the initial Temperature values of the zones. However, the patch only works in the first project run. In the next runs, the patch is not run as it should, so the initial temperatures are not correctly assigned to my models' zones. How can I permanently initialize the flow field or automate the initialization process to run in the beginning of each run? I thank you in advance, Best regards, Hugo Silva |
ansys fluent 2019r3 |
[swak4Foam] swakExpression not writing to log | alexfells | OpenFOAM Community Contributions | 3 | March 16, 2020 19:19 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
how 2 freeze 1 phase flow field & start lagrangian | KK | CFX | 5 | February 14, 2008 17:48 |
External flow field. | Moon | FLUENT | 3 | March 5, 2003 11:32 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
