fatal error: cyclicAMILduInterface.H: No such file or directory
Old   January 15, 2021, 18:09
Default fatal error: cyclicAMILduInterface.H: No such file or directory
Massachusetts
yoshimi is on a distinguished road
Hello experts,
I installed OpenFOAM 8 today, and the installation went fine. I ran an OpenFOAM example and it worked just fine.
However, when I tried to run 'wmake' on custom code files, I got the following error:
/opt/openfoam8/src/finiteVolume/lnInclude/cyclicAMIFvPatch.H:39:10: fatal error: cyclicAMILduInterface.H: No such file or directory
   39 | #include "cyclicAMILduInterface.H"
compilation terminated.
make: *** [/opt/openfoam8/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/ysofcFoam.o] Error 1
I figured the issue must be with my options. I followed the advice in this post from 2016:
https://github.com/wyldckat/wallShearStressLES/issues/1
to no avail.
Currently, this is what my Make/options file looks like:
EXE_INC = \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude
EXE_LIBS = \
    -lfiniteVolume \
    -lmeshTools
Any help will be much appreciated!
~yoshimi
yoshimi is offline   Reply With Quote
Old   January 15, 2021, 18:17
Kira
aero_head is on a distinguished road
Hello Yoshimi,
Looks like there is a problem with that header file. You might have better luck posting this question to the OpenFOAM forum: https://www.cfd-online.com/Forums/op...st-processing/
Hope you are able to find a solution to your problem.
aero_head is offline   Reply With Quote
Old   January 15, 2021, 21:55
Massachusetts
Thanks, I will close this thread.
cfd - post, openfoam8
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
