Is Viscous Dissipation always equal to Drag Power Loss |
January 6, 2021, 14:52 |
Raphael
Rep Power: 14 |
If we have a cylinder rotating inside a concentric stationary cylinder with a fluid in between them, will the total viscous dissipation in the fluid domain be equal to the total drag force multiplied with the velocity of the spinning cylinder?
Seems to me like it has to be the case, but if someone can confirm or elaborate, it would be appreciated. |
January 6, 2021, 15:21 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
Are you talking about the "Taylor-Couette" flow? This is the case where you have an exact solution (see for example in Kundu). The viscous dissipation (viscosity*D) is present in the kinetic energy equation, you can assume a steady flow and integrate the equation in the domain to check the balance between the terms. For this case we should always deduce that the dissipation of kinetic energy is balanced by the production of kinetic energy provided by the system. |
January 6, 2021, 15:32 |
#3 | |
Raphael
Rep Power: 14 |
Is there an exact solution even when the flow is turbulent? |
January 6, 2021, 15:55 |
#4 | |
Rep Power: 73 |
No, for turbulence you work on the statistically averaged equations that are not closed analytically. However, for statistically steady turbulence (and this is the case) you can say that the production equates the dissipation of kinetic energy. |
January 6, 2021, 16:34 |
Raphael
Rep Power: 14 |
Can you define production and dissipation of kinetic energy? Is it as I defined it above?
January 26, 2022, 09:29 |
Paul Norman
Hi arkie87,
I think it should be the case that there is mechanical energy balance in your simulation. A time average of the work being done by the wall (Tauw*v_Wall) should equal to a time average the energy being dissipated in your flow field by viscous dissipation. That being said, I have seen simulations where the numbers don't appear to add up, for example see this thread: Underestimated dissipation by LES I think you may also have to account the the effective numerical viscous dissipation of your finite volume schemes to get an exact balance. |
drag power loss, rotating cylinder, viscous dissipation |
Residuals and forces spiraling out of control before failing | edomalley1 | OpenFOAM Running, Solving & CFD | 3 | September 7, 2018 11:42 |
Estimation of viscous Lift & Drag coefficients from inviscid flow in optimization. | freebird | Main CFD Forum | 1 | June 3, 2018 04:40 |
How can I compute viscous drag and pressure drag in ANSYS? | Panri93 | FLUENT | 0 | January 24, 2017 07:05 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
How to obtain correct viscous pressure drag using CFX? | Ketut Utama | Main CFD Forum | 1 | January 25, 1999 06:05 |
