January 4, 2021, 01:38 |
Problem with Running OpenFOAM Parallel Case
Homer Bacanto
Rep Power: 5 |
Hey guys, I'm trying to run an OpenFOAM case in parallel, specifically in 56 cores/processors. When I try running the Allrun file, I get through everything just fine until I reach the solver. It solves for a couple of minutes until it terminates because I get the following error:
[amd64-TRX40-AORUS-PRO-WIFI:11125] *** An error occurred in MPI_Bsend [amd64-TRX40-AORUS-PRO-WIFI:11125] *** reported by process [1304035329,1] [amd64-TRX40-AORUS-PRO-WIFI:11125] *** on communicator MPI COMMUNICATOR 3 SPLIT FROM 0 [amd64-TRX40-AORUS-PRO-WIFI:11125] *** MPI_ERR_BUFFER: invalid buffer pointer [amd64-TRX40-AORUS-PRO-WIFI:11125] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort, [amd64-TRX40-AORUS-PRO-WIFI:11125] *** and potentially your MPI job) [amd64-TRX40-AORUS-PRO-WIFI:11112] PMIX ERROR: UNREACHABLE in file ../../../src/server/pmix_server.c at line 2193 [amd64-TRX40-AORUS-PRO-WIFI:11112] PMIX ERROR: UNREACHABLE in file ../../../src/server/pmix_server.c at line 2193 [amd64-TRX40-AORUS-PRO-WIFI:11112] 2 more processes have sent help message help-mpi-errors.txt / mpi_errors_are_fatal [amd64-TRX40-AORUS-PRO-WIFI:11112] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages If anyone can point me in the right direction, I'd be very grateful. |
blastfoam, mpirun error, openfoam |
[snappyHexMesh] Problem with boundaries with sHM in parallel running | Loekatoni | OpenFOAM Meshing & Mesh Conversion | 0 | January 24, 2019 07:56 |
Running OpenFOAM parallel with different OpenFoam directories? | massive_turbulence | OpenFOAM Running, Solving & CFD | 0 | November 19, 2018 15:08 |
Problem running movingCylinders case in parallel with foam-extend-3.1 | mhkenergy | OpenFOAM Running, Solving & CFD | 5 | March 3, 2017 05:20 |
running multiple parallel cases in openfoam slows the simulation | kkpal | OpenFOAM Running, Solving & CFD | 2 | August 21, 2015 11:08 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
