Damping effects of a Non Newtonian fluid on a resonating rotating disk. |
December 31, 2020, 11:04 |
AH
I have worked out a rotating disk immersed in a non Newtonian fluid.
Q: Now I have linked the ANSYS harmonic tool with ANSYS CFX. Can't get the Non Newtonian damping effects to work correctly. Any suggestions please? Thanks. |
January 11, 2021, 01:12 |
Kira
Rep Power: 8 |
What do you mean you cannot get the damping effects to work correctly? Do you apply them and it gives you an error? Strange data? Also, are you using the harmonic response analysis with Workbench or something else? |
Simulating object rotating within fluid | ray1988 | OpenFOAM Pre-Processing | 1 | June 26, 2019 10:32 |
UDF to drag coefficient and non newtonian fluid | liliana | Fluent UDF and Scheme Programming | 1 | April 1, 2019 05:54 |
Heat transfer between solid rotating and stationary fluid domains | DCSERE | CFX | 2 | November 17, 2015 03:43 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
