Particles following the flow trajectory
Like Tree10Likes
Old   January 24, 2021, 10:19
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Consider a pipe filled with water (single phase) being at the rest. This case is still compatible to produce a non-vanishing gradient of the density rho since
drho/dt +v .Grad rho = - rho div v
is satisfied for a zero velocity field. You can also write Drho/Dt=0 that means that a particle of water retain its density along the trajectory that, in this case, is just the position at the rest. Of course, the representation by means of the discrete particles depends on the number of finite particles of water you use.
You can do the same reasoning for water moving in the pipe, being now
drho/dt +v .Grad rho = Drho/Dt =0
Shabi likes this.
FMDenaro is offline   Reply With Quote
advection equation, particle concentration, transport equation, volume fraction.
Will the results of steady state solver and transient solver be same? carye OpenFOAM Running, Solving & CFD 9 December 28, 2019 06:21
How to simulate particles in a gas flow sara OpenFOAM Running, Solving & CFD 13 October 8, 2019 06:12
Choosing a solver to model particles at rest in a flow field Nigel Bruce Khan OpenFOAM Running, Solving & CFD 0 March 22, 2019 09:35
Particles in the flow nissen21 Fluent Multiphase 5 May 21, 2014 20:21
Interpolate particles together with flow asal FLUENT 0 March 30, 2014 15:22
