Particle following trajectories of the flow
Old   December 21, 2020, 16:35
Default Particle following trajectories of the flow
Shabi
Shabi is on a distinguished road
Consider a simple 2D channel where the flow enters the domain from one side with the inlet velocity boundary condition with a constant value and it forms a boundary layer.
1) If i add many number of particles consistently to the inlet and neglect all inertial forces and let it to follow the flow trajectories, is there any difference if my particles are massless, or if they are neutral buoyant?
2) If the particles is going to follow the flow trajectories, is it true that the volume fraction of the particle in the domain (C) is the solution of the advection equation, dC/dt + div (vC) = 0? If so,
3) If the inlet boundary condition for C is the constant value of 1, we know that in the steady state whole domain will be filled with the uniform value of C=1. But, it contradicts with what we expect with the particle case. Because if we add particles to the inlet consistently, because of the boundary layer, we expect a non-uniform value for the volume fraction in the steady state, because it is not possible to have a uniform distribution of particles in the domain in the steady state.
Thank you in advance for sharing your ideas.
Shabi is offline   Reply With Quote
advection equation, concentration, convection
3 Phase Modelling (particle flow in droplet) Peter Ehab Fluent Multiphase 3 July 21, 2016 13:29
Lagrangian Particle Tracking in Eulerian-Eulerian Multiphase Flow DarrenC CFX 5 April 7, 2016 15:50
injection problem Mark New FLUENT 0 August 4, 2013 02:30
Transient analysis of particle flow with Fluid-Structure Interaction (FSI) Julian K. CFX 2 September 15, 2011 16:30
How do I get particle trajectories Amar FLUENT 1 May 20, 2004 16:05
