SolidWorks External FlowSim Incorrect Result
Old   December 19, 2020, 12:12
Post SolidWorks External FlowSim Incorrect Result
Vince Ace
vincevince is on a distinguished road
Hello, I am a student using solidworks in analyzing my project about tidal turbine. I'm new to using flow sim but i know the result of my sim is incorrect. I did an external flow sim, did all the other basic necessary settings in the wizard (that i know of), that includes addition of local averaging rotation, and a stream flow of 1.27m/s. I then selected a rotating region and used available rpm data as input. Also, I only tweaked the computational domain, rotating region, goals and mesh under 'input data' The results showed unreasonable water flow velocity profile, such as higher than input velocities at the leading edge of the blade, the root of the blade (faster than the tip's), and in the wake. I have attached some pictures to show you. Anyone who can help me with this? Thank you so much!
vincevince is offline   Reply With Quote
cfd, cfd analysis, solidworks, solidworks flow, turbine
Coupling to external code using MPI calls from within a solver Regis_ OpenFOAM Programming & Development 0 October 31, 2017 11:50
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 02:40
Can't get data from OpenFoam to external solver using externalCoupled perry OpenFOAM Running, Solving & CFD 4 May 26, 2014 09:09
how to create a wall as a boundary condition for external flow in solidworks mangotango Main CFD Forum 4 November 16, 2012 14:22
Update boundary conditions calculated by an external program CedricVH OpenFOAM 2 January 15, 2010 12:55
