Saving the meanVelocityForce-based momentumSource data |
December 17, 2020, 12:10 |
Omid
Hi all,
I'm running a 2D steady simulation of the periodic hill case, similar to the steady state OF tutorial case. For the simulation I apply a force in the momentum equation in order to maintain a mean velocity, by using the meanVelocityForces in the fvOptions as follows: Code:
momentumSource { type meanVelocityForce; active yes; //on/off switch meanVelocityForceCoeffs { selectionMode all; //cellSet // points //cellZone fields (U); Ubar (0.020188 0 0 ); relaxation 1.0; } } I would like to be able to save the data for this source term at every time step. Can someone please advise if this is possible? If so, how should one go about implementing it. Cheers, Last edited by jerkato; December 17, 2020 at 12:13. Reason: Code not appearing with the right format |
July 6, 2021, 08:43 |
Andrea Di Ronco
Rep Power: 9 |
Hi Omid,
if I got it right, you were looking for a way to compute/save the acceleration source equivalent to the velocity-correction approach on which meanVelocityForce is based? Did you find a solution? I'd be interested Thanks, Andrea |
fvoptions momentum source, openfoam |
Saving Ansys Data in as a mat. file in Matlab | Niko9310 | ANSYS | 0 | August 13, 2014 11:46 |
SSD (Solid-state drive) for Fluent data reading and saving | Anna Tian | FLUENT | 1 | July 16, 2014 13:55 |
UDF for saving data of a transient simulation at particular locations | sreerajvarma | Fluent UDF and Scheme Programming | 3 | July 16, 2014 07:00 |
[OpenFOAM] saving data in paraview | aylalisa | ParaView | 3 | May 31, 2014 11:38 |
saving data along a line | Philip | FLUENT | 2 | February 7, 2006 03:18 |
