December 15, 2020, 13:07 |
wmake error in solidDisplacementFoam
Saga
x86_64-w64-mingw32-g++ -m64 -std=c++11 -Dcygwin64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -DMSWIN -DLITTLE_ENDIAN -DMSWIN -DLITTLE_ENDIAN -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I. -IsolidDisplacementThermo -IderivedFvPatchFields/tractionDisplacement -IderivedFvPatchFields/hydrostaticDisplacement -I/opt/OpenFOAM/OpenFOAM-dev/src/thermophysicalModels/basic/lnInclude -I/opt/OpenFOAM/OpenFOAM-dev/src/thermophysicalModels/solidThermo/lnInclude -I/opt/OpenFOAM/OpenFOAM-dev/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-dev/src/meshTools/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-dev/src/OSspecific/MSWindows/lnInclude -c tractionDisplacement/tractionDisplacementFvPatchVectorField.C -o Make/cygwin64mingw-w64DPInt32Opt/tractionDisplacement/tractionDisplacementFvPatchVectorField.o
tractionDisplacement/tractionDisplacementFvPatchVectorField.C: In constructor ‘Foam::tractionDisplacementFvPatchVectorField::tra ctionDisplacementFvPatchVectorField(const Foam::tractionDisplacementFvPatchVectorField&, const Foam::fvPatch&, const Foam:imensionedField<Foam::Vector<double>, Foam::volMesh>&, const Foam::fvPatchFieldMapper&)’: tractionDisplacement/tractionDisplacementFvPatchVectorField.C:64:38: error: no matching function for call to ‘Foam::Field<Foam::Vector<double> >::Field(const vectorField&, const Foam::fvPatchFieldMapper&)’ 64 | pressure_(tdpvf.pressure_, mapper) | ^ In file included from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/Field.H:339, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/labelField.H:39, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/primitiveFields.H:37, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/pointField.H:36, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/edge.H:40, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/edgeList.H:32, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/PrimitivePatch.H:56, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/primitivePatch.H:35, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/polyPatch.H:43, from /opt/OpenFOAM/OpenFOAM-dev/src/finiteVolume/lnInclude/fvPatch.H:39, from /opt/OpenFOAM/OpenFOAM-dev/src/finiteVolume/lnInclude/fvPatchField.H:47, from /opt/OpenFOAM/OpenFOAM-dev/src/finiteVolume/lnInclude/fvPatchFields.H:29, from tractionDisplacement/tractionDisplacementFvPatchVectorField.H:39, from tractionDisplacement/tractionDisplacementFvPatchVectorField.C:26: /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/Field.C:184:1: note: candidate: ‘Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = Foam::Vector<double>; Foam::label = int]’ 184 | Foam::Field<Type>::Field | ^~~~ /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/Field.C:184:1: note: candidate expects 3 arguments, 2 provided /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/Field.C:177:1: note: candidate: ‘Foam::Field<Type>::Field(Foam::Istream&) [with Type = Foam::Vector<double>]’ 177 | Foam::Field<Type>::Field(Istream& is) | ^~~~ /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/Field.C:177:1: note: candidate expects 1 argument, 2 provided /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/Field.C:163:1: note: candidate: ‘Foam::Field<Type>::Field(const Foam::tmp<Foam::Field<Type> >&, const labelListList&, const scalarListList&) [with Type = Foam::Vector<double>; Foam::labelListList = Foam::List<Foam::List<int> >; Foam::scalarListList = Foam::List<Foam::List<double> >]’ 163 | Foam::Field<Type>::Field | ^~~~ /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/Field.C:163:1: note: candidate expects 3 arguments, 2 provided /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/Field.C:149:1: note: candidate: ‘Foam::Field<Type>::Field(const Foam::UList<T>&, const labelListList&, const scalarListList&) [with Type = Foam::Vector<double>; Foam::labelListList = Foam::List<Foam::List<int> >; Foam::scalarListList = Foam::List<Foam::List<double> >]’ 149 | Foam::Field<Type>::Field | ^~~~ /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/Field.C:149:1: note: candidate expects 3 arguments, 2 provided /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/Field.C:136:1: note: candidate: ‘Foam::Field<Type>::Field(const Foam::tmp<Foam::Field<Type> >&, const labelUList&) [with Type = Foam::Vector<double>; Foam::labelUList = Foam::UList<int>]’ 136 | Foam::Field<Type>::Field | ^~~~ /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/Field.C:139:23: note: no known conversion for argument 2 from ‘const Foam::fvPatchFieldMapper’ to ‘const labelUList&’ {aka ‘const Foam::UList<int>&’} /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/PackedList.C:539:6: note: template argument deduction/substitution failed: tractionDisplacement/tractionDisplacementFvPatchVectorField.C:210:27: note: ‘Foam::Ostream’ is not derived from ‘const Foam::PackedList<nBits>’ 210 | writeEntry("value", os); | ^ In file included from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/spatialTransform.H:203, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/septernion.H:46, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/transformField.H:40, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/transformer.H:45, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/coupledPolyPatch.H:41, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/processorPolyPatch.H:42, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/processorTopology.H:30, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/globalMeshData.H:84, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/GeometricBoundaryField.C:28, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/GeometricField.C:1619, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/GeometricField.H:717, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/GeometricScalarField.H:38, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/GeometricFields.H:34, from /opt/OpenFOAM/OpenFOAM-dev/src/finiteVolume/lnInclude/volFields.H:37, from tractionDisplacement/tractionDisplacementFvPatchVectorField.C:28: /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/spatialTransformI.H:288:13: note: candidate: ‘void Foam::writeEntry(Foam::Ostream&, const Foam::spatialTransform&)’ 288 | inline void writeEntry(Ostream& os, const spatialTransform& st) | ^~~~~~~~~~ /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/spatialTransformI.H:288:33: note: no known conversion for argument 1 from ‘const char [6]’ to ‘Foam::Ostream&’ 288 | inline void writeEntry(Ostream& os, const spatialTransform& st) | ~~~~~~~~~^~ make: *** [/opt/OpenFOAM/OpenFOAM-dev/wmake/rules/General/transform:26: Make/cygwin64mingw-w64DPInt32Opt/tractionDisplacement/tractionDisplacementFvPatchVectorField.o] Error 1 |
December 16, 2020, 02:38 |
duri
Rep Power: 17 |
Have you changed to source code?
pressure_(tdpvf.pressure_, mapper) there is no constructor available for this method. The source code I have is like this, pressure_(mapper(tdpvf.pressure)). Some inconsistency in the code, if you are using git try to figure out the changes and revert back. |
[OpenFOAM.org] Not found many .so files when installing OpenFOAM 6 | lengjun | OpenFOAM Installation | 2 | December 12, 2022 23:08 |
Problems Installing OF 1.6 32 bit | bucksfan | OpenFOAM Installation | 19 | August 4, 2009 02:36 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 05:41 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 22:45 |
[OpenFOAM] ParaFoam error message | joey | ParaView | 1 | October 2, 2006 14:28 |
