free VOF source code?
Old   July 3, 2000, 11:56
Default free VOF source code?
Pei-Ying Hsieh
Anyone knows of a place that I can get a free VOF source code (2D will be fine, and any type of VOF will be OK too). Thanks!
Pei-Ying Hsieh, Ph.D.
Old   July 3, 2000, 13:07
Default Re: free VOF source code?
John C. Chien
(1). visit the website of flow sciences at http://www.flow3d.com/ (also a sponsor of this forum). (2). I think, you can find the inventor of the VOF method at the same location.
Old   July 4, 2000, 15:20
Jim Park
John's on track as usual.
Flow-3d is the commercial child of sola-vof, the original 2-d vof implementation.
If you're located in the US, you might be able to get source code from the Los Alamos National Lab (try http://gnarly.lanl.gov/Home.htm). If not, perhaps they can tell you where to ask.
You might try NASA for a copy of nasa.vof-2d or -3d, slightly enhanced versions of sola-vof.
Good luck.
Old   July 5, 2000, 09:46
Pei-Ying Hsieh
Hi, Jim,
I tried Los Alamos's web side (that you posted). All their codes (such as RIPPLE, CFDLIB, ...etc) are not free.
I did tried flow3d's web site also, no luck!
How can I get nasa.vof-2d (3d)?
Thanks!
Pei-Ying
Old   July 5, 2000, 12:28
Jim Park
Maybe you should try to get the reports. The Fortran listings are printed in them. It's a lot of work (unless you get a good quality copy and can scan the code), but the price is right. Unless you need the extra stuff in the NASA version, the SOLA version is a lot shorter.
Nichols, B. D., C. W. Hirt, and R. S. Hotchkiss, "SOLA-VOF: A solution Algorithm for Transient Fluid Flow with Multiple Free Surfaces," Los Alamos Scientific Laboratory Report LA-8355, August, 1980.
Torrey, Martin D., Lawrence D. Cloutman, Raymond C. Mjolness, and C. W. Hirt, "NASA-VOF2D: A Computer Program for Incompressible Flows with Free Surfaces," Los Alamos National Laboratory Report, December, 1985.
Your institution's library should be able to find copies of these for you. They might try the Department of Energy (DOE) repository or NASA repositories.
Good luck!
Old   July 5, 2000, 14:54
Pei-Ying Hsieh
Hi, Jim,
Thanks for the info. I found these reports (pdf format) from Los Alamos's on-line library.
Best,
Pei-Ying
open source code of k-e turbulence model. karuna Main CFD Forum 1 June 4, 2006 11:09
about cfd code, free or for payment John M Main CFD Forum 6 September 15, 2003 09:59
free RANS code with free surface ability Lou jing Main CFD Forum 1 July 11, 2003 15:43
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 16:56
Code with reliable free surface capability in a rotating system Subhasish Roy Choudhury Main CFD Forum 1 September 4, 1998 19:47
