Correct Inlet Boundary Condition at Pressure Vessel
Old   December 8, 2020, 05:15
Default Correct Inlet Boundary Condition at Pressure Vessel
SimonStar's Avatar
Simon
SimonStar is on a distinguished road
Hello everyone,
I want to simulate the stream jet out of a pressure vessel. The vessel has a small valve where the jet comes out. This valve is the Inlet of the simulation.
My problem is to find the correct inlet-boundary-condition.
The vessel has for example a dp of 10 bar to the outside. And it is large enough that the pressure inside is not doping when opening the valve for a short time.
I have two options: static-pressure-inlet-condition 10 bar or total-pressure-inlet-condition 10 bar?
Which one is the correct one?
Thank you,
Simon
SimonStar is offline   Reply With Quote
Old   December 8, 2020, 19:51
Lucky
Total pressure is technically more correct but you might find that it really doesn't affect the flow much whichever one you use.
Old   December 9, 2020, 14:52
SimonStar's Avatar
Simon
Thank you very much for answering, Lucky Tran. It helped me very much!
I just have one more question:
I made the total-pressure-inlet-condition in my simulation.
What I see now is that the velocity is very high right after the valve (up to 800m/s). This is normal I guess.
But the total pressure is rising in this area about 50%. Is this also normal?
What makes me thinking is the following: The total pressure normally stays at the same level (except friction issues) while the static and dynamic pressure are varying. So how can it increase right after the inlet?
Thank you again,
Simon
boundary condition, inlet, pressure, vessel
Inlet & outlet both pressure boundary condition shouvik ghorui OpenFOAM 5 November 1, 2022 05:39
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
