thamer
Rep Power: 11 ![]() |
Hello everyone,
Am working on a simulation implying a rigid body, Actually, am receiving a warning on CFX solver saying: ''WARNING: Rotational degrees of freedom have not converged. Maximum number of iterations exceeded. Rigid Body: Rigid Body 1 Number of Iterations: 26 Residual on Angular Momentum Equation: 8.36441E-02'' the solver doesn't stop as it's not a major problem, when going on CFD-post I can clearly see the body rotating, I don't know if this kind of warning may cause the divergence of my simulation. Any help would be very appreciated, Thanks in advance |
Kira
Rep Power: 8 ![]() |
Hello Thamer,
What is the Courant number/CFL for the simulation? |
#3 | |
thamer
Hey, i just stopped the simulation because it's not converging, and here's the average scale information: RMS Courant Number = 7.2565E+01 Maximum Courant Number = 6.4815E+02 |
Kira
Hello Thamer,
Those seem pretty high, possibly the cause of the divergence. What time step size are you using for your simulation, and what is your smallest grid node size? I ask because the CFL criteria is ![]() Where ![]() ![]() From my understanding, from theory, if the Courant number is <=1, fluid particles move from one cell to another within one time step (at most). If it is >1, fluid particles move through two or more cells at each time step and this can affect convergence negatively. In general, lower time step to lower Courant number, raise time step to increase Courant number. The distance between grid node elements also plays a role as well, as per the equation. Another cause for the divergence may be poorly set boundary conditions. So, if you give us information on: 1. The selected time step size, 2. The min/max grid node element size and 3. The boundary conditions you used we may get a better sense of what the cause of the divergence is. |
thamer
i looked after what u mentioned and yeah, i think my meshing is too small concerning the time step that am selecting. Am gonna try to go with a big very big mesh in order to see if my code is working right or no. If you're interested we may have a call or screen share within teams to discuss that. Thanks |
cfx, rigid body motion, warning message |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
[swak4Foam] installing funkySetFields | prapanj | OpenFOAM Community Contributions | 65 | October 8, 2015 17:46 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
