Transformation matrix between species mass fraction and species density
Old   November 30, 2020, 02:34
Default Transformation matrix between species mass fraction and species density
learner00 is on a distinguished road
The species mass fraction is defined as following Y_s = \frac{\rho_s}{\rho}.
I want to compute the following derivative: \frac{\partial Y_k}{\partial \rho_s}
From my calculation, I thought that it should be \frac{\partial Y_k}{\partial \rho_s} = \frac{\partial (\rho_k/\rho)}{\partial \rho_k} \frac{\partial \rho_k}{\partial \rho_s} =    \dfrac{1}{\rho} \delta_{ks}
However, I was told that the value should be \frac{\partial Y_k}{\partial \rho_s} = \left(\delta_{ks}-Y_k\right) \frac{1}{\rho}.
Can you help me by pointing out where I made the mistake in the computation?
learner00 is offline   Reply With Quote
Old   December 3, 2020, 20:13
Eifoehn4's Avatar
Eifoehn4 is on a distinguished road
Your calculation is not correct. You are not allowed to put \rho outside the bracket because \rho is a function of \rho_k or \rho_s. Note that in general one suppose that the entities are \rho_k and not \rho.
The correct calculation is:
\frac{\partial Y_1}{\partial \rho_1}
= -\frac{\partial Y_2}{\partial \rho_1} =-\frac{\partial (\rho_2 / \rho) }{\partial \rho_1}= - \rho_2 \frac{\partial( 1  / \rho) }{\partial \rho_1}=     - \rho_2 \frac{\partial ( 1  / (\rho_1 +\rho_2)) } {\partial \rho_1}=\dots
\dots= -\rho_2 \left(-\frac{1 }{( \rho_1 +\rho_2 )^2}\right) =  -\rho_2 \left(-\frac{1 }{\rho^2}\right) = \frac{Y_2 }{\rho} =  \frac{1-Y_1 }{\rho}
The same can be done with:
\frac{\partial Y_1}{\partial \rho_2}
= -\frac{\partial Y_2}{\partial \rho_2}=\dots
Regards
Check out my side project:
A multiphysics discontinuous Galerkin framework: Youtube, Gitlab.
Eifoehn4 is offline   Reply With Quote
Species Mole and Mass Fraction Macro combustion FLUENT 18 February 5, 2024 13:23
Mass fraction of species (Y) in reacting solvers mike.franky OpenFOAM Running, Solving & CFD 9 February 9, 2023 07:49
mass fraction of species Lilly FLUENT 5 March 13, 2022 18:52
Define mass flow profile with regards to species mass fraction danS Fluent UDF and Scheme Programming 0 June 20, 2017 07:21
Multi Species Problem (mass fraction) usamaperwez CFX 0 July 27, 2016 08:07
