November 20, 2020, 10:02 |
Soy drying simulation
Felipe Leonardo
Hello, I'm currently trying to work out how to proceed in the simulation of a fixed bed dryer. I'm using the Euler granular multiphase model (with packed bed enabled), aswell as the species model (soy-water(liquid), air-water(vapour)). I'm trying to verify the behaviour of different models for the mass transfer, but I can't seem to make the species-mass-transfer model work. I'm using Equilibrium Ratio, and ranz-marshall for the from and to phase, but can't properly understand what the Mass Fraction Equilibrium Ratio means. Is it simply the mass concentration of water in soy divided by the mass concentration of water in the water? If so, the boundary conditions for the air at the inlet considers a completely dry air, with a fraction of water of 0, which wouldn't allow a proper value. Plus, this value is constantly changing as the operation goes on, since water is removed from the soy to the air. Should I write an UDF? Am I using the right model?
Thanks in advance for your help. |
drying, euler granular model, species model |
Mapping Field Data for Mesh Regions from Another Simulation | veterator | OpenFOAM Pre-Processing | 1 | July 10, 2018 06:28 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 03:28 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 16:06 |
Simulation of high pressure diesel injector - all phases compressible with cavitation | fivos | CFX | 4 | July 30, 2015 07:48 |
drying rate simulation for iron ore pellet | wali | Fluent Multiphase | 0 | July 9, 2014 18:08 |
