Can prism layers get smaller as you move further from the wall?
Old   November 2, 2020, 06:29
Default Can prism layers get smaller as you move further from the wall?
Jack Hayton
Jack Hayton is on a distinguished road
Is it possible for prism layers to decrease in size as you move further from the wall?
I have chosen a given near wall thickness to achieve a desired y+. With the total thickness/number of layer settings my prism layers are of equal size and provide decent resolution of the flow in the high gradient area. However, If I would want to achieve even higher resolution I would need thinner prism layers without changing the thickness of the near wall layer (To keep y+ the same). This would mean that the first layer would be relatively thick, with the layers afterwards being smaller.
1. Does doing this make any sense?
2. Is it possible?
Thanks,
Jack
Jack Hayton is offline   Reply With Quote
prism layer meshing, prism layers
temperature correction limited- Star ccm+ LpSingh STAR-CCM+ 15 September 29, 2020 12:06
[ICEM] How to improve bad quality elements that are obtained after creating prism layers? Rohith Giridhar ANSYS Meshing & Geometry 2 July 11, 2015 19:04
[ICEM] Prism layers distorted near trailing edge of blade-Unstructured Mesh Rohith Giridhar ANSYS Meshing & Geometry 3 June 29, 2015 18:52
[ICEM] Large elements after creating prism layers khoopes ANSYS Meshing & Geometry 4 June 17, 2013 14:05
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
