Choosing solver for pressure inlet boundary condition |
October 29, 2020, 06:50 |
Sesh
Rep Power: 8 |
Dear all, as I'm new to CFD, I really need some advice to choose the solver and turbulence model.
I have a pack of cylinders(solid, T=25degC) with 2mm space in between placed in a box(cube with air, T=25degC). I have a small pressure inlet (2mm) at the corner and the gas (say CO2) comes out of it with a pressure 3MPa and a temperature 1000degC. Obviously, the flow is turbulent. I have to solve for the heat transfer between this pressurized high-temperature jet and solids. Can someone suggest me the solver (Pressure based or density-based) and turbulence model to be used? many thanks. |
density based solver, pressure based solver, turbulence modeling |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 02:44 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 05:58 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
