surface tension vs flow
Old   October 22, 2020, 20:01
Default surface tension vs flow
IL
fdnovice7629 is on a distinguished road
hello
i have a drip tube with water dripping and when i increase the flow rate or frequency of drips they get bigger/more massive.
i see the equation mass x gravity = 3.14(tube diameter)(surface tension)
my mass is changing but not gravity, 3.14 or tube diameter so surface tension must be related to flow rate but I cant find anything online on how to figure this out.
conversely I have a known flow rate and mass and want to determine tube diameter but unsure how to get it as it appears surface tension must be related to flow rate but I dont know how
fdnovice7629 is offline   Reply With Quote
drips, drop, flow rate, surface tension, water
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? EternalSeekerX SU2 3 October 9, 2020 19:28
modeling pipe flow with strong surface tension phsieh2005 OpenFOAM 0 August 27, 2009 14:51
two phase flow with surface tension qunwuhe@hotmail.com Main CFD Forum 2 October 21, 2007 01:29
two-phase flow with variable surface tension yf Main CFD Forum 1 May 19, 2006 10:58
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
