[isoAdvector] Different results with polyhedral and hexahedral mesh
Old   October 21, 2020, 08:31
Default [isoAdvector] Different results with polyhedral and hexahedral mesh
Liz
redTo is on a distinguished road
Hello eveybody,
I'm using compressibleInterIsoFoam (OF v2006) for a nozzle spray simulation and I'm comparing the results between polyMesh and hexaMesh.
For both cases I have defined the same conditions and the results are really different (see attached file).
Any idea why is this happening?
I'm grateful for any help!
Cheers,
Liz
PS: Inlet condition: nozzle bottom 4,6 g/s
outlet condition: outlet box 1 bar
fvSolution
solvers
    "alpha.oil.*"
        nAlphaCorr      1;
        nAlphaSubCycles 3;
        cAlpha          1;
        reconstructionScheme plicRDF;
        vof2IsoTol 	1e-8;
        surfCellTol 	1e-6;
        nAlphaBounds    3;
        snapTol         1e-12;
        clip            true;
    "pcorr.*"
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-7;
        relTol          0.01;
    ".*(rho|rhoFinal)"
        solver          diagonal;
    p_rgh
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-8;
        relTol          0.01;
    p_rghFinal
        $p_rgh;
        relTol          0;
    "(U|T|k|epsilon|B).*"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-08;
        relTol          0;
PIMPLE
    momentumPredictor no;
    nOuterCorrectors 1;
    nCorrectors     3;
    nNonOrthogonalCorrectors 0;
relaxationFactors
     fields
        "p.*"           0.1;
    equations
        "k.*" 0.7;
	"epsilon.*" 0.7;
	"U.*" 0.8;
fvSchemes
 ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    div(rhoPhi,U)  Gauss upwind;
    div(phi,alpha)  Gauss vanLeer;
    div(phirb,alpha) Gauss interfaceCompression;
    div(phi,thermo:rho.oil) Gauss upwind;
    div(phi,thermo:rho.air) Gauss upwind;
    div(phi,k)      Gauss upwind;
    div(rhoPhi,k)   Gauss upwind;
    div(phi,epsilon) Gauss upwind;
    div(rhoPhi,epsilon)  Gauss upwind;
    div(rhoPhi,T)  Gauss upwind;
    div(rhoPhi,K)  Gauss upwind;
    div(phi,p)      Gauss upwind;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
redTo is offline   Reply With Quote
compressibleinterfoam, isoadvector
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 06:02
Polyhedral Mesh Diego Flores FLUENT 17 August 21, 2020 14:52
Fluent warning Hexahedral or polyhedral cell problems lehoanganh07 FLUENT 1 November 6, 2013 02:49
[ANSYS Meshing] Hexahedral and polyhedral cell problems lehoanganh07 ANSYS Meshing & Geometry 0 November 3, 2013 10:42
Fluent 6.3.16 + Polyehdral Meshes Carlos FLUENT 3 March 15, 2007 04:09
