Reading a sequence of libraries as Execute Commands
Old   October 14, 2020, 06:38
Default Reading a sequence of libraries as Execute Commands
Majd
Benyounes is on a distinguished road
Dear comunity,
I am new to Fluent and have the following problem:
In the Fluent Calculation I'm analysing, I need to read/import a squence of 5 Libraries (containing Forces Files). My goal is to import one library at every timestep and repeat the same sequence periodically.
What I did:
I wrote 5 Execute Commands each with one of the 5 libraries. Under "Every" I enter respectively (1, 2, 3, 4, 5) and under "When" I enter (Timestep).
In the calculation parameters I have following parameters:
No. of timesteps --> 15.000
Timestep --> 0.002 (since the Frequency is 100 Hz, ´with 5 Forces files I import 5 files (execute 5 execute commands) at every period.)
The goal is to make the timesteps repeat for 30 seconds with the same order.
Problem:
The 5 timesteps are executed respecting the right order. When it comes to the 2nd Period (starting from the 6th timestep), the order is not respected anymore.
For example at the 13th timestep: Instead of executing the execute command that imports the file no. 3, Fluent runs another execute command.
I hope you got my problem and could propose a solution to solve it. Thank you very much.
I tried with Macors and Journal Files and it has been always the same problem!
Benyounes is offline   Reply With Quote
execute command, execute commands, fluent, fluent - udf, import data
Python / R libraries for reading postProcessing data Gerry Kan OpenFOAM Post-Processing 4 September 28, 2020 20:34
if statement in execute commands mohamadalimirzaei1994 FLUENT 3 July 23, 2020 05:14
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 19:19
[Commercial meshers] Problem converting fluent mesh vinz OpenFOAM Meshing & Mesh Conversion 28 October 12, 2015 07:37
OpenFOAM14 for Mac OSX Darwin 104 gschaider OpenFOAM Installation 118 July 20, 2008 06:19
