Fluent UDF - Distinguish particles from two different injections |
L.A.Isanka
Rep Power: 6 ![]() |
Hello!
Im working on a model to separate micro particles based on dipole interaction forces. Heterogeneous microspheres are injected using 2 injections, injection 0 & injection 1. Do you know of a method to distinguish between particles injected from these injections.Injected particles from both injections are identicle execpt for their surface properties and I'm using dipole interactions to separate the particles injected via the two injections. The intecation force is different for the two injection. Thus, once a particle is located, I want to identify whether it is from injection 0 or injection 1. I'd be greatful if you could help me with this. Thank you! |
distinguish injections, fluent - udf, injections, interactions |
UDF for deleting particles in DPM | imanmirzaii | Fluent UDF and Scheme Programming | 12 | November 25, 2020 19:27 |
Passing udf value to fluent | durg | Fluent UDF and Scheme Programming | 2 | February 11, 2019 12:55 |
Fluent do not use my velocity field(by UDF) to solve energy equation | tangleiplus | Fluent UDF and Scheme Programming | 6 | January 21, 2019 21:28 |
My UDF works well with Fluent 16 but not with Fluent 19 | Ahmed A. Serageldin | Fluent UDF and Scheme Programming | 3 | October 19, 2018 11:38 |
Fluent DPM - incomplete particles | richard ben | FLUENT | 4 | September 26, 2014 11:37 |
