SPH code for two-phase (compressible/incompressible) flows
Old   September 29, 2020, 05:43
Default SPH code for two-phase (compressible/incompressible) flows
Manuel
Manuel CFD is on a distinguished road
I would need to simulate a two-phase (gas-liquid) flow with a compressible gas phase by means of SPH. The geometry is complex and it is given by stl files. Part of the domain boundary is moving and I have an inlet and an outlet as well. Are there any SPH codes (free or commercial) that I could use for this simulation?
Thank you for your help.
Regards
Manuel
Manuel CFD is offline   Reply With Quote
Old   October 11, 2020, 02:39
Default SPH code
ves
Veskov Eugene
ves is on a distinguished road
Hi, Manuel!
Look at:
https://spheric-sph.org/sph-projects-and-codes
https://dual.sphysics.org/
https://wiki.manchester.ac.uk/sphysi....php/Main_Page
https://pysph.readthedocs.io/en/latest/
dual sphysics have most improved plugins for complex geometry processing
ves is offline   Reply With Quote
Old   October 12, 2020, 11:37
Manuel
Hi ves,
thank you for your reply and suggestions.
I have already been trying to use DualSPHysics for my simulation. But I will need to implement the Inlet/Outlet boundary condition for multiphase flows, because this feature is not currently supported. However, the very good point is that I can import the stl files.
I had also a look at the documentation of PySPH. It is mentioned in Overview/Changelog that an STL importer was added in the version of November 2018. However, I was not able to find any examples with the import of a complex geometry. Do you know whether this is actually possible in PySPH? If yes, where can I find an example to learn how to import a geometry?
Thank you.
Regards
Manuel
Old   December 17, 2020, 13:43
Default complex geometry
ves
Veskov Eugene
I don't know how work with geometry in pySPH. You may link OpenFOAM classes for mesh reading with DuaSPH or pySPH. GMESH reader, some mesh generation software and other reader https://people.sc.fsu.edu/~jburkardt/.
You need only points from mesh
Old   December 17, 2020, 13:47
Default inlet/outlet bc
ves
Veskov Eugene
Read PhD from
I have my realisation outlet bc for G. R. Liu books fortran code. This code simple and easy to read and modification
Old   December 20, 2020, 07:34
Default SPH code for two-phase flows
Manuel
Hi ves,
thank you for the hints and the reference. I will have a look at it.
Regards
Manuel
compressible, inlet and outlet, moving boundary, sph method, two phase flow
Quasi 1-D Nozzle Flows Matlab Code CFDdummy Main CFD Forum 5 October 30, 2019 01:27
twoPhaseEulerFoam drift flows in non-orthogonal mesh and dilute phase tkeskita OpenFOAM Bugs 2 August 10, 2015 08:30
multiphaseEulerFoam: Flows of phase through faces of cells maybee OpenFOAM Programming & Development 1 March 13, 2014 16:35
multiphase granular flows; options for secondary phase RockOn FLUENT 1 January 15, 2013 07:59
About 3D sph code Noor Main CFD Forum 0 January 25, 1999 05:10
