September 28, 2020, 04:34 |
Fiction heat on Ansys Fluent
Dongjun Lee
Rep Power: 6 |
In the process of analysing fluid sloshing movement in a sealed tank, does Fluent calculate the friction heat generated by the fluid hitting the tank wall by itself? If not, do I have to enter the elements that I consider through UDF? Thank you for your helps, |
September 28, 2020, 12:48 |
Lucky
Rep Power: 66 |
You need to turn on viscous heating option in viscous models. It's usually off by default, for some models it is always on. Best way to check is to open up your case and turn it on.
September 30, 2020, 05:16 |
Dear LuckyTran,
#3 | |
Dongjun Lee
Rep Power: 6 |
I turn on 'SST k-w model' and viscous heating too. And do i have to turn on 'wall adhesion too? Could you teach me what i should to consider for viscous heating modeing? It is caused by fluid movement around the wall. |
fluent - udf, sloshing tank, sloshingtank3d |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
how to modeling heat by fluent and ansys? | njiit | FLUENT | 0 | December 9, 2009 01:39 |
FLUENT to ANSYS Temperature Mapping Procedure | schreiberc1 | FLUENT | 0 | June 29, 2006 14:50 |
