Restoring openFoam/SimFlow to default settings |
September 17, 2020, 22:09 |
Bob Tipton
Rep Power: 6 |
I had been successfully running a large number of analyses using a combination of openFOAM and SimFlow.
The purpose of my research is to maximize the drag coefficient on a sail like device and I was close to the culminating analysis for a paper. When I took all of the early research from the project and incorporated it into a new design - the CFD analysis diverged badly. This has been the case throughout the project because the entire goal is to maximize a vortex. After making some changes to the default settings of SimFlow (which may have modified the default settings for openFOAM?) I can no longer successfully mesh anything. As I was experimenting with changing the settings I failed to make note of the original values and now I cannot go back. As of this point SnappyHexMesh is badly broken - either running through SimFlow or through the command line. It seems my best course of action is a full reset to the original conditions. The problem is in the snapping phase. The mesh divides well and boundary layers are applied, but the resulting mesh is very finely castellated - not smooth to the model. I'm running on Win-10 using Windows Subsystem for Linux. Simflow is running directly under windows but I'm running the analyses from a WSL console window. The only hardware I have access too is a mid range HP laptop with 8 GB of RAM. It is very under powered for this task, but it's been getting the job done up until now. FYI this is an unfunded, under resourced effort so I don't have access to large computational resources. |
September 17, 2020, 22:53 |
More info
Bob Tipton
Rep Power: 6 |
I was able to mesh in SimFlow again.
However I need access to more features than SimFlow can provide. When I try to run the same case from the command line using snappyHexMesh I get results like the attached one. I recall that I had been able to run blockMesh and snappyHexMesh on the output from SimFlow - but when I do that now I get the attached image. My sequence of calls is surfaceFeatureExtract blockMesh snappyHexMesh I have also run blockMesh before surfaceFeatureExtract but from my understanding they are order independent. FoamFile { version 2.0; class dictionary; format ascii; location "system"; object blockMeshDict; } convertToMeters 1; edges ( ); vertices ( (-5.0 0.0 0.0) (15.0 0.0 0.0) (15.0 10.0 0.0) (-5.0 10.0 0.0) (-5.0 0.0 10.0) (15.0 0.0 10.0) (15.0 10.0 10.0) (-5.0 10.0 10.0) ); blocks ( hex (0 1 2 3 4 5 6 7) (40 20 20) simpleGrading (1.0 1.0 1.0) ); boundary ( boundaries { type patch; faces ( (2 6 5 1) (3 7 6 2) (4 5 6 7) (0 4 7 3) ); } symmetry { type symmetry; faces ( (1 5 4 0) (0 3 2 1) ); } ); FoamFile { version 2.0; class dictionary; format ascii; location "system"; object snappyHexMeshDict; } castellatedMesh true; snap true; addLayers true; geometry { Inner.stl { type triSurfaceMesh; simflowType stl; name Inner; includedAngle 120.0; } Mid.stl { type triSurfaceMesh; simflowType stl; name Mid; includedAngle 120.0; } Outer.stl { type triSurfaceMesh; simflowType stl; name Outer; includedAngle 120.0; } Refinement.stl { type triSurfaceMesh; simflowType stl; name Refinement; includedAngle 120.0; } } castellatedMeshControls { locationInMesh (3.3 2.45 2.6); refinementSurfaces { Inner { level ( 4 4 ); patchInfo { type wall; } } Mid { level ( 5 5 ); patchInfo { type wall; } } Outer { level ( 5 5 ); patchInfo { type wall; } } } refinementRegions { Refinement { mode inside; levels ((1.0E30 2)); } } limitRegions { } features ( { file "Inner.eMesh"; levels ((0 0)); } { file "Mid.eMesh"; levels ((0 0)); } { file "Outer.eMesh"; levels ((0 0)); } ); maxLocalCells 500000; maxGlobalCells 4000000; nCellsBetweenLevels 4; maxLoadUnbalance 0.1; minRefinementCells 10; resolveFeatureAngle 30.0; allowFreeStandingZoneFaces true; } snapControls { tolerance 1.0; nSmoothPatch 3; nSolveIter 500; nRelaxIter 5; nFeatureSnapIter 10; implicitFeatureSnap true; explicitFeatureSnap true; multiRegionFeatureSnap true; nFaceSplitInterval 5; } addLayersControls { layers { Inner { nSurfaceLayers 5; expansionRatio 1.15; firstLayerThickness 0.1; } Inner_patch0 { nSurfaceLayers 5; expansionRatio 1.15; firstLayerThickness 0.1; } Mid { nSurfaceLayers 5; expansionRatio 1.15; firstLayerThickness 0.1; } Mid_patch0 { nSurfaceLayers 5; expansionRatio 1.15; firstLayerThickness 0.1; } Outer { nSurfaceLayers 5; expansionRatio 1.15; firstLayerThickness 0.1; } Outer_patch0 { nSurfaceLayers 5; expansionRatio 1.15; firstLayerThickness 0.1; } } relativeSizes true; minThickness 0.001; firstLayerThickness 1.0E-4; expansionRatio 1.25; nGrow 0; featureAngle 180.0; maxFaceThicknessRatio 0.5; nSmoothSurfaceNormals 5; nSmoothThickness 10; minMedialAxisAngle 90.0; maxThicknessToMedialRatio 0.5; nMedialAxisIter 100; nSmoothNormals 3; slipFeatureAngle 30.0; nRelaxIter 5; nBufferCellsNoExtrude 0; nLayerIter 50; nRelaxedIter 20; detectExtrusionIsland true; } meshQualityControls { maxNonOrtho 65.0; maxBoundarySkewness 20.0; maxInternalSkewness 4.0; maxConcave 80.0; minVol 1.0E-14; minTetQuality 1.0E-20; minArea -1.0; minTwist 0.02; minTriangleTwist -1.0; minDeterminant 0.01; minFaceWeight 0.05; minVolRatio 0.01; minVolCollapseRatio 0.1; nSmoothScale 4; errorReduction 0.75; relaxed { maxNonOrtho 75.0; } } mergeTolerance 1.0E-6; debug 0; |
meshing, simflow, snappyhexmesh |
Changing fluent default settings | sunilpatil | FLUENT | 5 | November 25, 2019 01:16 |
SU2 Inviscid Hypersonic Solver Settings | jclegg | SU2 | 2 | April 10, 2019 12:35 |
changing default unit in Gambit | NISHIKANT TAMRAKAR | FLUENT | 6 | May 20, 2016 02:22 |
CFX-Pre problem, pls help!!! | cth_yao | CFX | 0 | February 17, 2012 01:52 |
solver settings, residuals plateau for a long time | Mumawalde | CFX | 2 | December 17, 2007 09:49 |
