Why Q-criterion does not show the gradients on whole surface?
Old   September 11, 2020, 12:25
Default Why Q-criterion does not show the gradients on whole surface?
MA
mazhar16823 is on a distinguished road
Hi everyone,
I have performed steady state simulation for a wind turbine blade using STARCCM+. Now, I want to demonstrate the velocity gradients on the blade. Although, I have created an isosurface and Q-Criterion by varying the isovalue from 50 - 1000, but I see that gradients are represented on half of the blade and half blade is taken away. Actually, I want to compare my Q-criterion with the reference Q-criterion from Large eddy simulation. Could you please suggest how to fix this issue - I want to have the gradients all along the blade surface. You can see in the figures, for LES gradients are represented on the whole surface whereas in my case I don't get them throughout.
Thanks for your time.
mazhar16823 is offline   Reply With Quote
Old   September 11, 2020, 13:37
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by mazhar16823 View Post
Hi everyone,
In no way you can compare the steady state simulation to the instantaneous LES field. You must do a time averaging of the LES fields and then compare them.
FMDenaro is online now   Reply With Quote
Old   September 11, 2020, 13:51
MA
Thanks for your kind input.I am trying to represent the velocity gradients on the whole blade surface using RANSE; Is not it possible? Since there is void on half of the blade. I have varied the velocity scale and Isovalue for the Q-criterion as well.
postprocessing, starccm+
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
solid edge problem....can you help? cindy Main CFD Forum 3 April 5, 2004 14:43
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 07:47
