specify tangential velocity
Old   September 8, 2020, 04:00
Default specify tangential velocity
ARAVIND SRIDHARA
aravind vashista is on a distinguished road
hi users,
I am simulating a swirl burner which has a central fuel jet and swirling air coming out of the annulus. The central fuel jet has axial velocity = 32 m/s and swirling air has axial and tangential velocity components as 32 m/s and 19 m/s respectively. I use velocity inlet boundary conditions to specify inlet boundary conditions for both fuel and air. For swirling air I use
velocity specification method : components
reference frame : absolute
coordinate system : cylindrical ( radial, tangential, axial)
radial = 0
tangential = 19
axial = 32.
am I correctly specifying boundary conditions?
aravind vashista is offline   Reply With Quote
boundary conditions, swirl flow, velocity inlet
UDF comilation error. urgent help please m zubair Fluent UDF and Scheme Programming 4 February 10, 2019 12:19
tangential, axial and radial velocity in swirling Al-Hashimi FLUENT 1 June 23, 2013 11:30
Surface normal velocity BC with zero gradient tangential, cylinder c_dowd OpenFOAM Running, Solving & CFD 0 May 25, 2013 08:22
Cyclone Tangential Velocity ... Abdul FLUENT 2 August 13, 2008 01:07
Radial and tangential velocity Antonio Mileo FLUENT 2 February 16, 2001 02:41
