How to set the colormap of ANSYS CFD-Post to be the same as MATLAB? |
August 27, 2020, 10:35 |
Henry
Rep Power: 7 |
I am comparing 2D-contoured results in CFD-Post (computed by ANSYS Fluent) with experimental data, which is processed by MATLAB. To compare CFD result and experimental data in a fair manner, their colormap (including style, number of color levels, RGB value for each level, etc.) must be exactly the same. However, the colormap in MATLAB (such as "jet", "hsv", "grey" etc.) cannot be found in CFD-Post, and vice versa. Could anyone tell me how to resolve this issue? Do I need to switch to other CFD post-processing software?
I believe this is typical question for anyone who want to compare MATLAB-processed experimental data with ANSYS-computed CFD results... |
August 27, 2020, 19:55 |
Rep Power: 14 |
I spent 10s with Google. It is not that hard.
Matlab https://github.com/DrosteEffect/BrewerMap https://de.mathworks.com/matlabcentr...form-colormaps Ansys Fluent https://github.com/jrwrigh/fluent_colormaps Suggestion: You may use Viridis for both. Regards |
cfd-post, ensight, matlab, postprocessing |
Ansys Licence Serve on Ubuntu 16.04 LTS | david.pasquale | ANSYS | 2 | January 20, 2017 12:52 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 06:31 |
2-way FSI in Ansys CFX 15 | LucasGasparino | CFX | 3 | August 6, 2015 04:17 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 10:53 |
Using ICEM CFD to repair/edit ANSYS Meshing | Kaaji1359 | ANSYS | 2 | July 30, 2013 11:28 |
