Implementation of DO Radiation in Ansys Fluent
Old   August 22, 2020, 09:34
Default Implementation of DO Radiation in Ansys Fluent
Subham
subham998 is on a distinguished road
I have been trying to implement the DO Radiation Model to simulate a radiation beam in Ansys Fluent since the past 1 month without much success. The computational domain consists of a cylinder of 10 cm radius and 1 m length and the front section of the cylinder is specified as irradiated wherein incident radiation enters the domain. Air and dust particles are present inside the cylinder.
I have set the absorptivity of air to zero in the simulation, and the theta and phi extent corresponding to the beam width is set to 1e-06. I have also set the theta and phi pixels and divisions equal to 15. I am expecting the incident radiation to be constant intensity over the entire domain, however, I what I am observing is that the intensity of incident radiation decreases with the axial length, and finally attains a constant value after a certain distance.
I would highly appreciate your support in solving the issue. Please let me know in case any additional information is required.
subham998 is offline   Reply With Quote
Old   August 22, 2020, 10:43
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Any particular reason to not use the actual DO already present in Fluent?
sbaffini is offline   Reply With Quote
Old   August 22, 2020, 11:21
Subham
I am actually using the DO radiation inbuilt in Ansys Fluent. Apologies if it was not clear in the question
Old   August 22, 2020, 11:28
sbaffini's Avatar
Paolo Lampitella
It's just that "implementation" typically refers to the work of making available something that wasn't before the said work.
Can't give you much help on the rest. Surely, your question belongs more to the Fluent forum than here
Fluent in Ansys Workbench : Change Working Directory sral FLUENT 4 March 29, 2019 11:29
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 04:34
2-way FSI in Ansys CFX 15 LucasGasparino CFX 3 August 6, 2015 04:17
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
[GAMBIT] 3.5 years overtake by Ansys: Where are the enhancements in grid generation Volker P. ANSYS Meshing & Geometry 22 January 17, 2012 18:27
