Identifying location of turbulence model shift in DES or SST models
Old   August 14, 2020, 08:39
Default Identifying location of turbulence model shift in DES or SST models
Jonas Svantesson
Jonassvantesson is on a distinguished road
Is there a standard or convenient way of identifying where in my domain the solution shifts from one turbulence model to another when using for example a DES model or the k-w SST Model?
For the k-w SST Model the shift should be close to the walls, but how close?
For DES models the shift from LES to RANS should be controlled by the mesh element size, but if we have a gradual increase in element size, can we identify exactly where the shift is?
I believe this may be important when doing a Mesh Sensitivity Analysis. If a mesh is so coarse that it does not utilize the LES part of the DES turbulence model, can it really be considered the same model and representative for the MSA?
Thank you for any input!
Jonassvantesson is offline   Reply With Quote
Old   August 14, 2020, 20:29
Lucky
Depends on which particular implementation/software you are using. There is usually a blending function that keeps track of how much LES-like and how much RANS-like the solution is in each region. You have to figure out how to retrieve the value of the blending function for whatever you are using. SST model also uses its own blending functions to switch from epsilon to omega.
Old   October 9, 2020, 12:52
Default DES: grid induced separation around foil
Clément_G's Avatar
Clément Gouriou
Clément_G is on a distinguished road
Hi Jonas and all foamers,
I'm not sure if you need to visualize DES Region, but we also investigate which model controls which region of the mesh to make our simulation converge correctly.
We are simulating wind tunnel experiment of a flow around an airfoil at 85000 Reynolds number and try to recover the experimental results measured with pressure sensors on the center line of our experimental airfoil.
We have tested komega-SST DDES model with 2 types of meshes varying the axial length of 1st layer cells from 3.1 mm to 8.2 mm. Unfortunately, we encounter a first layer treated by the LES model instead of komegaSST model in the foil boundary layer for both cases... This phenomenon leads likely to GIS (Grid Induced Separation) because we observe early flow separation on the suction side of the airfoil. It is likely the reason of our bad results you can see in the chart attached (DES_results_10deg.png).
Just as well for our faith in CFD (;-)), DDES-SA model with the same mesh (1st layer axial length = 3.1 mm) gives good results in agreement with the experiment .
Does somebody has any hint to prevent the DDES model to switch in LES for the 1st layer? Do we have to modify any shield function or do we still have to enlarge our mesh cells in axial direction?
Thank you for your advice.
Clément
File Type: txt DES_coefficient.txt (713 Bytes, 1 views)
Clément_G is offline   Reply With Quote
des, sst k-w, turbulence modeling
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 19:19
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
SST turbulence model PCFD CFX 56 June 20, 2017 16:45
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
