Optimal tolerance and variables scaling settings
Old   July 28, 2020, 09:56
Post Optimal tolerance and variables scaling settings
4513645ygq is on a distinguished road
Hello everyone,
I use my app based on MOOSE to simulate the transient natural convection process in 3D faulted geothermal field (only involving thermal and hydraulic coupling process) recently. After learning some tips on the MOOSE homepage and other questions in the moose-users group, my tolerance and variables scaling settings in input files are as follows:
[Variables]
[./pressure]
[./temperature]
scaling =1e-10
[Executioner]
type = Transient
solve_type = NEWTON
end_time = 3e+13
dtmax = 3e+8
l_tol = 1e-08
nl_rel_tol = 1e-8
nl_abs_tol = 1e-10
l_max_its = 20
nl_max_its = 20
[./TimeStepper]
type = IterationAdaptiveDT
dt = 50
growth_factor = 1.5
I selected two representative steps’ output logs to let you know that nl_rel_tol have more effect at the beginning steps and nl_abs_tol have more effect on the later steps.
Time Step 1, time = 50, dt = 50
Computing initial residual [#[33m 1.40 s#[39m]
0 Nonlinear |R| = #[32m1.209085e-01#[39m
|residual|_2 of individual variables:
pressure: 0.120907
temperature: 0.000551279
0 Linear |R| = #[32m1.209085e-01#[39m
1 Linear |R| = #[32m9.214533e-03#[39m
2 Linear |R| = #[32m3.527436e-04#[39m
3 Linear |R| = #[32m2.304453e-05#[39m
4 Linear |R| = #[32m2.394151e-06#[39m
5 Linear |R| = #[32m2.902817e-07#[39m
6 Linear |R| = #[32m4.435598e-08#[39m
7 Linear |R| = #[32m7.554398e-09#[39m
8 Linear |R| = #[32m1.231253e-09#[39m
9 Linear |R| = #[32m2.408428e-10#[39m
1 Nonlinear |R| = #[32m4.844599e-06#[39m
pressure: 5.08119e-10
temperature: 4.8446e-06
0 Linear |R| = #[32m4.844599e-06#[39m
1 Linear |R| = #[32m2.921005e-07#[39m
2 Linear |R| = #[32m2.104554e-08#[39m
3 Linear |R| = #[32m1.945979e-09#[39m
4 Linear |R| = #[32m2.931182e-10#[39m
5 Linear |R| = #[32m4.963045e-11#[39m
6 Linear |R| = #[32m8.706768e-12#[39m
7 Linear |R| = #[32m1.727647e-12#[39m
8 Linear |R| = #[32m3.411377e-13#[39m
9 Linear |R| = #[32m7.365310e-14#[39m
10 Linear |R| = #[32m1.738410e-14#[39m
2 Nonlinear |R| = #[32m1.082855e-10#[39m
pressure: 4.26112e-12
temperature: 1.08202e-10
#[32m Solve Converged!#[39m
Time Step 1449, time = 4.23737e+11, dt = 3e+08
Computing initial residual . [#[33m 2.53 s#[39m]
0 Nonlinear |R| = #[32m1.921806e-05#[39m
pressure: 5.96239e-07
temperature: 1.92088e-05
0 Linear |R| = #[32m1.921806e-05#[39m
1 Linear |R| = #[33m1.917473e-05#[39m
2 Linear |R| = #[32m1.815117e-05#[39m
3 Linear |R| = #[32m1.258791e-05#[39m
4 Linear |R| = #[32m6.910255e-06#[39m
5 Linear |R| = #[32m1.816211e-06#[39m
6 Linear |R| = #[32m5.852820e-07#[39m
7 Linear |R| = #[32m1.039703e-07#[39m
8 Linear |R| = #[32m2.785164e-08#[39m
9 Linear |R| = #[32m7.704200e-09#[39m
10 Linear |R| = #[32m1.995736e-09#[39m
11 Linear |R| = #[32m6.900243e-10#[39m
12 Linear |R| = #[32m2.072931e-10#[39m
13 Linear |R| = #[32m5.978403e-11#[39m
14 Linear |R| = #[32m1.525856e-11#[39m
15 Linear |R| = #[32m4.042695e-12#[39m
16 Linear |R| = #[32m8.816408e-13#[39m
17 Linear |R| = #[32m2.648039e-13#[39m
18 Linear |R| = #[32m8.917245e-14#[39m
9 Nonlinear |R| = #[32m4.233214e-11#[39m
pressure: 4.49907e-13
temperature: 4.23297e-11
Outputing exodus .
Actually, the huge time consuming of my tolerance and variables scaling settings (even though I can get my expected results) make me wonder whether there are optimal settings (more looser and also can get my expected results) for my problem. I also consider using ‘automatic_scaling= true’ and ‘compute_scaling_once= false’ in my input file. But it will not converge in later steps.
Performing automatic scaling calculation
Computing initial residual . [#[33m 2.48 s#[39m]
0 Nonlinear |R| = #[32m3.632860e+04#[39m
pressure: 36328.6
temperature: 6.17362e-05
0 Linear |R| = #[32m3.632860e+04#[39m
1 Linear |R| = #[32m2.768653e+03#[39m
2 Linear |R| = #[32m1.059854e+02#[39m
3 Linear |R| = #[32m6.923729e+00#[39m
4 Linear |R| = #[32m7.192601e-01#[39m
5 Linear |R| = #[32m8.717260e-02#[39m
6 Linear |R| = #[32m1.331006e-02#[39m
7 Linear |R| = #[32m2.258615e-03#[39m
8 Linear |R| = #[32m3.633758e-04#[39m
9 Linear |R| = #[32m6.715652e-05#[39m
1 Nonlinear |R| = #[32m1.518016e-04#[39m
pressure: 0.000151801
temperature: 5.42533e-07
Outputing exodus .
Time Step 37, time = 3.27625e+08, dt = 1.09208e+08
0 Nonlinear |R| = #[32m5.129066e+01#[39m
pressure: 51.221
temperature: 2.6728
0 Linear |R| = #[32m5.129066e+01#[39m
1 Linear |R| = #[32m1.996509e+01#[39m
2 Linear |R| = #[32m1.280559e+01#[39m
3 Linear |R| = #[32m2.635866e+00#[39m
4 Linear |R| = #[32m5.564897e-01#[39m
5 Linear |R| = #[32m8.132326e-02#[39m
6 Linear |R| = #[32m1.647094e-02#[39m
7 Linear |R| = #[32m3.398670e-03#[39m
8 Linear |R| = #[32m5.097928e-04#[39m
9 Linear |R| = #[32m7.921325e-05#[39m
10 Linear |R| = #[32m1.038931e-05#[39m
11 Linear |R| = #[32m1.455114e-06#[39m
12 Linear |R| = #[32m2.304993e-07#[39m
1 Nonlinear |R| = #[32m4.219714e-03#[39m
pressure: 0.00413905
temperature: 0.000821135
0 Linear |R| = #[32m4.219714e-03#[39m
1 Linear |R| = #[32m3.801014e-03#[39m
2 Linear |R| = #[32m6.171899e-04#[39m
3 Linear |R| = #[32m7.636873e-05#[39m
4 Linear |R| = #[32m1.856455e-05#[39m
5 Linear |R| = #[32m3.511850e-06#[39m
6 Linear |R| = #[32m8.791660e-07#[39m
7 Linear |R| = #[32m2.256941e-07#[39m
8 Linear |R| = #[32m3.132803e-08#[39m
9 Linear |R| = #[32m5.204031e-09#[39m
10 Linear |R| = #[32m9.246075e-10#[39m
11 Linear |R| = #[32m1.413886e-10#[39m
12 Linear |R| = #[32m2.510542e-11#[39m
2 Nonlinear |R| = #[32m1.393795e-06#[39m
pressure: 5.94444e-07
temperature: 1.26068e-06
0 Linear |R| = #[32m1.393795e-06#[39m
1 Linear |R| = #[33m1.393604e-06#[39m
2 Linear |R| = #[32m1.322582e-06#[39m
3 Linear |R| = #[32m4.109166e-07#[39m
4 Linear |R| = #[32m5.179491e-08#[39m
5 Linear |R| = #[32m7.772392e-09#[39m
6 Linear |R| = #[32m9.490397e-10#[39m
7 Linear |R| = #[32m1.445967e-10#[39m
8 Linear |R| = #[32m3.886349e-11#[39m
9 Linear |R| = #[32m1.333509e-11#[39m
10 Linear |R| = #[32m3.184414e-12#[39m
11 Linear |R| = #[32m4.942097e-13#[39m
12 Linear |R| = #[32m7.298691e-14#[39m
13 Linear |R| = #[32m1.139653e-14#[39m
pressure: 5.59225e-07
temperature: 1.01366e-11
0 Linear |R| = #[32m5.592251e-07#[39m
1 Linear |R| = #[32m3.705070e-09#[39m
2 Linear |R| = #[32m2.037853e-10#[39m
3 Linear |R| = #[32m1.369132e-11#[39m
4 Linear |R| = #[32m9.437461e-13#[39m
5 Linear |R| = #[32m8.278687e-14#[39m
6 Linear |R| = #[32m1.390563e-14#[39m
7 Linear |R| = #[32m2.615257e-15#[39m
20 Nonlinear |R| = #[31m5.669512e-07#[39m
pressure: 5.66951e-07
temperature: 1.01474e-11
#[31m Solve Did NOT Converge!#[39m
Could you please give me some suggestions on that? Thanks a lot.
Yan
4513645ygq is offline   Reply With Quote
