Jose
Rep Power: 0 ![]() |
Hello!
I have a doubt about the need to use under-relaxation. My currently project simulations consist in two steps: 1. Solve flow field. 2. Freeze the flow field and run the transport of a passive scalar (the passive scalar does not run during step 1). In this step, I monitor an average that should converge to a theoretical value. In the first simulation, I set no under-relaxation to the passive scalar (factor = 1) and I was happy with the results. Here is why: 1. The passive scalar is running alone, so it does not affect anything else. 2. The passive scalar residual reduced smoothly without instabilities or oscillations. 3. The value that I monitor converged to the theoretical value smoothly without any instabilities or oscillations. However, I was commanded to introduce under-relaxation in the passive scalar and the justification I was told was "not to rush the solution". I got sincerely puzzled by this, as do not understand this approach. So I have two questions: 1. Aren't my reasons enough to support the decision not to use any under-relaxation? What am I missing about this? Should I be looking into something else? 2. "not to rush the solution"... Shouldn't we try to rush the solutions as long as we do not introduce instabilities in the calculation? Thank you. |
passive scalar, under-relaxation factor |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
Division by zero exception - loop over scalarField | Pat84 | OpenFOAM Programming & Development | 6 | February 18, 2017 05:57 |
Issue symmetryPlane 2.5d extruded airfoil simulation | 281419 | OpenFOAM Running, Solving & CFD | 5 | November 28, 2015 13:09 |
Diverging solution in transonicMRFDyMFoam | tsalter | OpenFOAM Running, Solving & CFD | 30 | July 7, 2014 06:20 |
compressible flow in turbocharger | riesotto | OpenFOAM | 50 | May 26, 2014 01:47 |
